Terminated Pods to Be Reclaimed
It controls the number of terminated pods that can exist in a cluster. If there are more terminated pods than the expected number in the cluster, the terminated pods that exceed the number will be deleted and reclaimed.
Value Range
10 to 12500
If the cluster version is v1.21.11-r40, v1.23.8-r0, v1.25.6-r0, v1.27.3-r0, or later, the value range is changed to 0 to 100000.
If this parameter is set to 0, all pods in the terminated state will be retained.
Default Value
1000
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Set the parameter to 1000.
If the value is too large, there may be a large number of terminated pods in the cluster, which will further affect the performance of list queries and result in an overloaded cluster.
