Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Cluster/ Basic Settings/ Mask Bits of the Fixed IP Address Pool of Container Networks
Updated on 2025-06-13 GMT+08:00
It controls the number of mask bits of the fixed IP address pool of the container networks. It is supported only by the VPC network model (vpc-router).
The parameter determines the maximum number of IP addresses that can be assigned to containers on a node. This, along with the maxPods setting during node creation, determines the maximum number of pods that can be created on a node.
Value Range
From 24 to 28
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
