Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Clusters/ Network/ Network Model
Updated on 2025-11-11 GMT+08:00
Network Model
It specifies the network model used by containers in a cluster.
- overlay_l2: an overlay_l2 network (container tunnel network) built for containers using Open vSwitch (OVS)
- vpc-router: an underlay_l2 network built for containers using IPvlan and custom VPC routes
- eni: network model used by CCE Turbo clusters for external networks to access containers running in the clusters
Value Range
overlay_l2, vpc-router, or eni
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
Suggestions
Use CCE Turbo clusters.
