Elastic Bandwidth
The service bandwidth indicates the clean service bandwidth forwarded to the origin server from the AAD scrubbing center. It is recommended that the service bandwidth be greater than or equal to the egress bandwidth of the origin server.
Elastic bandwidth is the maximum bandwidth (postpaid) for your traffic.
Your traffic can exceed the service bandwidth for 36 hours per month. Beyond this limit, the protection capacity will be reduced. You are advised to enable elastic bandwidth.
After the elastic bandwidth is enabled, if your actual bandwidth exceeds the service bandwidth, the elastic bandwidth will be automatically enabled to avoid rate limiting and packet loss.
Billing Rules
The elastic bandwidth of CNAD can be billed in two modes: daily 95th percentile billing and monthly 95th percentile billing. The elastic bandwidth can range from 20% to 500% of the service bandwidth you purchased.
If your actual bandwidth exceeds the maximum elastic bandwidth, rate limiting and packet loss may occur. Select a bandwidth based on your traffic volume.
The elastic bandwidth fees in different scenarios are described as follows.
Service Bandwidth |
Elastic Bandwidth |
Actual Service Bandwidth |
Elastic Bandwidth Fee |
Description |
100 Mbit/s |
Disabled |
120 Mbit/s |
No elastic bandwidth fees will be generated. |
If bandwidth exceeds your configured quota, traffic may be limited and packet loss may occur. |
100 Mbit/s |
Enabled |
100 Mbit/s |
If the actual service bandwidth is less than or equal to the service bandwidth, no elastic service bandwidth fee is generated. |
100 Mbit/s |
Enabled |
120 Mbit/s |
Elastic bandwidth fees will be generated. |
If the actual bandwidth is higher than the service bandwidth, elastic service bandwidth fees will be generated. |
