Which Ports Cannot Be Accessed?
Some carriers will block the following ports for security reasons. It is recommended that you do not use the following ports.
| Protocol | Port |
| TCP | 42, 135, 137-139, 444, 445, 593, 1025, 1068, 1434, 3127-3130, 3332, 4444, 4789, 4790, 5554, 5800, 5900, 6669, 9996. |
| UDP | 135-139, 445, 593, 1026-1028, 1068, 1433, 1434, 4444, 4789, 4790, 5554, 9996, 17185. |
