Updated on 2023-12-14 GMT+08:00
Forwarding Rules
The number of forwarding rules is the number of TCP/UDP forwarding rules that can be added to the AAD instance. This parameter is available only when the access type is IP access. By default, 50 forwarding rules are provided. You can pay for more. A maximum of 200 forwarding rules are supported.
