Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using Spark/Spark2x/
Spark Troubleshooting
Updated on 2025-11-13 GMT+08:00
This section describes common faults that occur when Spark is used and troubleshooting methods.
- Common Spark Task Submission Faults
- Spark Task Submission Failure
- Spark Streaming Task Submission Issues
- Incorrect Parameter Format Is Displayed When a Spark Task Is Submitted
- Error "ClassNotFoundException" Is Reported When a Spark Task Is Submitted
- Driver Displays a Message Indicating That the Running Memory Exceeds the Threshold When a Spark Task Is Submitted
- Error "Can't get the Kerberos realm" Is Reported When a Spark Task Is Submitted in Yarn-Cluster Mode
- ApplicationMaster Fails to Start Twice When a Spark Task Is Submitted in Yarn-client Mode
- Job Status Is error After a Spark Job Is Submitted Through an API
- Failed to Connect to ResourceManager When a Spark Task Is Submitted
- Failed to Connect to the Driver When a Spark Job Is Submitted on a Node Outside the Cluster
- Common Spark Task Running Faults
- Spark Task Execution Failure
- An Error Is Reported When the Split Size Is Changed for a Running Spark Application
- A Spark Job Fails to Run Due to Incorrect JAR File Import
- Spark Job Suspended Due to Insufficient Memory or Lack of JAR Packages
- DataArts Studio Failed to Schedule Spark Jobs
- Large Number of Shuffle Results Are Lost During Spark Task Execution
- Failed to View Spark Task Logs
- Spark Streaming Task Failed but Status Shows as Successful in Yarn WebUI
- Why JRE fatal error after running Spark application multiple times?
- Spark Shuffle Exception Handling
- Common Faults of Spark Component Exceptions
- Spark, Hive, and Yarn Are Unavailable Due to Insufficient Disk Capacity
- Failed to Start spark-sql and spark-shell Due to JDK Version Mismatch
- Failed to Create or Delete a Table in Spark Beeline
- An Error Is Reported When spark-beeline Is Used to Query a Hive View
- Why Do I Fail to Create a Table in the Specified Location on OBS After Logging to Spark Beeline?
- Failed to Load Data to a Hive Table Across File Systems by Running SQL Statements Using Spark Shell
- An Error Occurs When SparkSQL Reads the ORC Table
- What Should I Do If Statistics of Hudi or Hive Tables Created Using Spark SQLs Are Empty Before Data Is Inserted?
- Failed to Switch to the Log Page from stderr and stdout on the Native Spark Web UI
- Why the Job Information Obtained from the restful Interface of an Ended Spark Application Is Incorrect?
- Why Cannot I Switch from the Yarn Web UI to the Spark Web UI?
- Apps Cannot Be Displayed on the JobHistory Page When an Empty Part File Is Loaded
- Why Does Spark Fail to Export a Table with the Duplicate Field Names?
- Why Does the Foreign Table Query Fail When Multiple Foreign Tables Are Created in the Same Directory?
- Why Does the Cluster Port Fail to Connect When a Client Outside the Cluster Is Installed or Used?
- How Do I Handle the Exception Occurred When I Query Datasource Avro Formats?
- Failed to Query Table Statistics by Partition Using Non-Standard Time Format When the Partition Column in the Table Creation Statement is timestamp
- How Do I Use Special Characters with TIMESTAMP and DATE?
- Common Spark Permission Authentication Faults
- Common JDBCServer Faults
- Common JobHistory Faults
Parent topic: Using Spark/Spark2x
