Offset Restoration from a Group and State Restoration from a Checkpoint in the Flink SQL Kafka Connector
This section applies only to MRS 3.6.0-LTS or later.
When you configure a Flink job, Kafka job recovery from a checkpoint supports restoring offsets from the consumer group and restoring state from the checkpoint.
Notes and Constraints
- Ensure that the Kafka topic names are consistent before and after checkpoint restoration.
- Make sure the Kafka group offset matches the checkpoint record. Otherwise, data may be missing.
How to Use
In the created Kafka Connector Source stream table, add the restore.mode setting and set its value to group-offsets.
Example SQL statements:
CREATE TABLE KafkaSource (
`user_id` VARCHAR,
`user_name` VARCHAR,
`age` INT
) WITH (
'connector' = 'kafka',
'topic' = 'test_source',
'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port',
'properties.group.id' = 'testGroup',
'scan.startup.mode' = 'latest-offset',
'format' = 'csv',
'properties.sasl.kerberos.service.name' = 'kafka',
'properties.security.protocol' = 'SASL_PLAINTEXT',
'properties.kerberos.domain.name' = 'hadoop.System domain name',
'restore.mode' = 'group-offsets'
CREATE TABLE KafkaSink(`user_id` VARCHAR, `value` BIGINT) WITH ('connector' = 'print');
Insert into
KafkaSink
select
user_id,
sum(age) as `value`
from
KafkaSource
group by
user_id; What is your overall rating for this page?
