SYNC_HIVE
This topic is available for MRS 3.5.0-LTS or later only.
Function
This command is used to synchronize Hudi tables stored in the Hudi data directory to Hive.
Syntax
call sync_hive(table => '[table]', tablePath => '[tablePath]')
Parameter |
Description |
Mandatory |
table |
Name of the table to be synchronized to Hive. |
Yes. If the table does not exist, it will be created. |
tablePath |
Storage path of the Hudi data directory |
Yes |
Example
call sync_hive(table => 'hudi_table', tablePath => '/user/hive/warehouse/hudi_table')
Response
You can view query results on the client.
