How Do I Connect to a Kudu Foreign Table When Ranger Is Enabled in Impala 4.3.0?
Question
After Ranger authentication is enabled, an error is reported when the following statement is used to create a foreign table:
CREATE TABLE db.table (id INT, dt TIMESTAMP, PRIMARY KEY(id)) PARTITION BY HASH PARTITIONS 16 STORED AS KUDU TBLPROPERTIES ( 'kudu.master_addresses' = 'master1:7051,master2:7051,master3:7051' );
The following error is reported.
CREATE TABLE db.table STORED AS KUDU TBLPROPERTIES ( 'kudu.table_name' = 'impala::db.table', 'kudu.master_addresses' = 'master1:7051,master2:7051,master3:7051' );
Answer
When Ranger authentication is enabled in the current Impala version, Kudu foreign tables cannot be created.
If the current cluster does not have the Kudu service, add --kudu_master_hosts=master1:7051,master2:7051,master3:7051 to the custom configuration of Impalad.
If the current MRS cluster has the Kudu service, you do not need to add this configuration. The default value of --kudu_master_hosts is the address of the KuduMaster in the current cluster.
Create a Kudu inner table.
STORED AS KUDU
