How Do I Install the Impala-shell Client on a Node Outside the MRS Cluster?
Question
The MRS Impala client installed on a node outside the MRS cluster cannot be accessed due to Python version issues. How do I install the client?
Answer
Use Pip to install the impala-shell client after configuring the image source.
- Run the following command to check whether the Python version is 2 or 3:
 - If the node is running EulerOS, HCE, or CentOS, run the following command to install the impala-shell client:
- For Python 2, run the following command:
yum install -y binutils binutils-devel gcc gcc-c++ python-devel cyrus-sasl-devel krb5-devel
pip install impala-shell
 - For Python 3, run the following command:
yum install -y binutils binutils-devel gcc gcc-c++ python3-devel cyrus-sasl-devel krb5-devel
 - If the node is running an Ubuntu OS, run the following command to install the impala-shell client:
apt install -y binutils binutils-dev gcc g++ python2-dev cyrus-dev libkrb5-dev
apt install -y binutils binutils-dev gcc g++ python3-dev cyrus-dev libkrb5-dev
- If the node is running a SUSE OS, run the following command to install the impala-shell client:
     Only SUSE 13.2 and later versions support impala-shell. Earlier versions do not support cyrus-sasl-devel and krb5-devel.
zypper install -y binutils binutils-devel gcc gcc-c++ python-devel cyrus-sasl-devel krb5-devel
After krb5-devel is installed, krb5-config will not be in the PATH directory. You need to create a symbolic link.
ln -s /usr/lib/mit/bin/krb5-config /usr/bin/krb5-config
zypper install -y binutils binutils-devel gcc gcc-c++ python3-devel cyrus-sasl-devel krb5-devel
   To log in to the system using the impala-shell client for a security client, you need to install the MRS client in the cluster and run the kinit <user> command.
