Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using HetuEngine/
        Common HetuEngine SQL Syntax/
        HetuEngine SQL Functions and Operators/
      Session Information
        Updated on 2024-12-13 GMT+08:00
Session Information
current_user
Description: Returns the current user.
select current_user;
current_user()
current_catalog
Description: Returns the current catalog name.
select current_catalog;
current_schema
Description: Returns the current schema name.
select current_schema;
   Parent topic: HetuEngine SQL Functions and Operators
