Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HetuEngine/
Common HetuEngine SQL Syntax/
HetuEngine SQL Functions and Operators/
Lambda Expression
Updated on 2024-12-13 GMT+08:00
Lambda Expression
The Lambda expression can be represented by ->.
x->x+1 (x,y)->x+y x->regexp_like(x,'a+') x->x[1]/x[2] x->IF(x>0,x,-x) x->COALESCE(x,0) x->CAST(xASJSON) x->x+TRY(1/0)
Most SQL expressions can be used in the Lambda function body except in the following scenarios:
- Subqueries are not supported.
x -> 2 + (SELECT 3)
- Aggregate functions are not supported.
x -> max(y)
Examples
- Use the transform() function to obtain the square of array elements.
SELECT numbers, transform(numbers, n -> n * n) as squared_numbers FROM (VALUES (ARRAY[1, 2]),(ARRAY[3, 4]),(ARRAY[5, 6, 7])) AS t(numbers); numbers | squared_numbers -----------|----------------- [1, 2] | [1, 4] [3, 4] | [9, 16] [5, 6, 7] | [25, 36, 49] (3 rows)
- Use the transform() function to convert array elements into strings. If the conversion fails, the array elements will be converted into NULL to avoid errors.
SELECT transform(prices, n -> TRY_CAST(n AS VARCHAR) || '$') as price_tags FROM (VALUES (ARRAY[100, 200]),(ARRAY[30, 4])) AS t(prices); price_tags -------------- [100$, 200$] [30$, 4$] (2 rows)
- When an operation is performed on an array element, other columns can also be used in the operation. For example, use transform() to calculate the linear equation f(x) =ax + b.
SELECT xvalues, a, b, transform(xvalues, x -> a * x + b) as linear_function_values FROM (VALUES (ARRAY[1, 2], 10, 5), (ARRAY[3, 4], 4, 2)) AS t(xvalues, a, b); xvalues | a | b | linear_function_values ---------|----|---|------------------------ [1, 2] | 10 | 5 | [15, 25] [3, 4] | 4 | 2 | [14, 18] (2 rows)
- Use any_match() to search for an array where at least one element is greater than 100.
SELECT numbers FROM (VALUES (ARRAY[1,NULL,3]), (ARRAY[10,200,30]), (ARRAY[100,20,300])) AS t(numbers) WHERE any_match(numbers, n -> COALESCE(n, 0) > 100); numbers ---------------- [10, 200, 30] [100, 20, 300] (2 rows) - Use regexp_replace() to capitalize the first letter.
SELECT regexp_replace('once upon a time ...', '^(\w)(\w*)(\s+.*)$',x -> upper(x[1]) || x[2] || x[3]); -- Once upon a time ... - Use the Lambda expression in the aggregate function. For example, use reduce_agg() to calculate the sum of elements by column.
SELECT reduce_agg(value, 0, (a, b) -> a + b, (a, b) -> a + b) sum_values FROM (VALUES (1), (2), (3), (4), (5)) AS t(value); sum_values ------------ 15 (1 row)
Parent topic: HetuEngine SQL Functions and Operators
