Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using HetuEngine/
        Common HetuEngine SQL Syntax/
        HetuEngine DDL SQL Syntax/
      SHOW CREATE VIEW
        Updated on 2024-12-13 GMT+08:00
SHOW CREATE VIEW
Syntax
SHOW CREATE VIEW view_name
This statement is used to display the SQL creation statement of a specified data view.
Example
To display the SQL statement that can be used to create the order_view view:
SHOW CREATE VIEW test_view;
              Create View
 CREATE VIEW hive.default.test_view AS
 SELECT
   orderkey
 , orderstatus
 , (totalprice / 4) quarter
 FROM
   orders
(1 row)
   Parent topic: HetuEngine DDL SQL Syntax
