Updated on 2024-12-13 GMT+08:00
SHOW FUNCTIONS
Syntax
SHOW FUNCTIONS [LIKE pattern [ESCAPE escapeChar]];
SHOW EXTERNAL FUNCTIONS;
SHOW EXTERNAL FUNCTION qualified_function_name;
Displays the definitions of all built-in functions.
Displays the description of all Java functions.
Displays the definition of a specified function.
Example
SHOW functions;
-- Use the LIKE clause.
show functions like 'boo_%';
 Function | Return Type | Argument Types | Function Type | Deterministic | Description
 bool_and | boolean     | boolean        | aggregate     | true          |
 bool_or  | boolean     | boolean        | aggregate     | true          |
(2 rows)
-- If a character in the matching character string conflicts with the wildcard, you can specify an escape character to identify the character. For example, to query all tables whose table name prefix is t_ in the default schema, set the escape character to \.
SHOW FUNCTIONS LIKE 'array\_%' escape '\';
|                                              Description                                               | Variable Arity | Built In
 array_agg       | array(T)    | T                               | aggregate     | true
| return an array of values        | false          | true
 array_contains  | boolean     | array(T), T                     | scalar        | true
| Determines whether given value exists in the array                                                     | false          | true
 array_distinct  | array(E)    | array(E)                        | scalar        | true
| Remove duplicate values from the given array                                                           | false          | true
 array_except    | array(E)    | array(E), array(E)              | scalar        | true
| Returns an array of elements that are in the first array but not the second, without duplicates.       | false          | true
 array_intersect | array(E)    | array(E), array(E)              | scalar        | true
| Intersects elements of the two given arrays                                                            | false          | true
 array_join      | varchar     | array(T), varchar               | scalar        | true
| Concatenates the elements of the given array using a delimiter and an optional string to replace nulls | false          | true
 array_join      | varchar     | array(T), varchar, varchar      | scalar        | true
 array_max       | T           | array(T)                        | scalar        | true
| Get maximum value of array        | false          | true
 array_min       | T           | array(T)                        | scalar        | true
| Get minimum value of array        | false          | true
 array_position  | bigint      | array(T), T                     | scalar        | true
| Returns the position of the first occurrence of the given value in array (or 0 if not found)           | false          | true
 array_remove    | array(E)    | array(E), E                     | scalar        | true
| Remove specified values from the given array                                                           | false          | true
 array_sort      | array(E)    | array(E)                        | scalar        | true
| Sorts the given array in ascending order according to the natural ordering of its elements.            | false          | true
 array_sort      | array(T)    | array(T), function(T,T,integer) | scalar        | true
| Sorts the given array with a lambda comparator.                                                        | false          | true
 array_union     | array(E)    | array(E), array(E)              | scalar        | true
| Union elements of the two given arrays        | false          | true
-- View all Java functions.
SHOW external functions;
  Function                  |   Owner
 example.namespace02.repeat | admintest
 hetu.default.add_two       | admintest
(2 rows)
-- View the definition of a specified function.
SHOW external function example.namespace02.repeat;
          External Function
External FUNCTION example.namespace02.repeat (
    s varchar,
    n integer
 RETURNS varchar
 COMMENT 'repeat'
 LANGUAGE JAVA
 DETERMINISTIC
 CALLED ON NULL INPUT
 SYMBOL com.test.udf.hetuengine.functions.repeat
 URI hdfs://hacluster/user/hetuserver/udf/data/hetu_udf/udf-test-0.0.1-SNAPSHOT.jar
 FUNCPROPERTIES (
    owner = 'admintest'
