SHOW TABLE/PARTITION EXTENDED
Syntax
SHOW TABLE EXTENDED [IN | FROM schema_name] LIKE 'identifier_with_wildcards' [PARTITION (partition_spec)]
This statement is used to display details about a table or partition.
Regular expressions can be used to match multiple tables at the same time, but cannot be used to match partitions.
The displayed information includes basic table information and file system information. The file system information includes the total number of files, total file size, maximum file length, minimum file length, last access time, and last update time. For a specified partition, its file system information is provided, instead of the file system information of the table where the partition is located.
Parameters
- IN | FROM schema_name
This parameter specifies the schema name. If this parameter is not specified, the current schema is used by default.
- LIKE 'identifier_with_wildcards'
identifier_with_wildcards supports only rule matching expressions that contain asterisks (*) and vertical bars (|).
The asterisk (*) can match one or more characters. The vertical bar (|) separates multiple matching rules.
Spaces at the beginning and end of a rule matching expression are not used for matching.
Example
-- Data preparation
create schema show_schema;
use show_schema;
create table show_table1(a int,b string);
create table show_table2(a int,b string);
create table from_table1(a int,b string);
create table in_table1(a int,b string);
-- Query the detailed information about tables whose names start with "show".
show table extended like 'show*';
tab_name
tableName:show_table1
owner:admintest
location:hdfs://hacluster/user/hive/warehouse/show_schema.db/show_table1
InputFormat:org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
OutputFormat:org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
columns:struct columns {int a,string b}
partitioned:false
partitionColumns:
totalNumberFiles:0
totalFileSize:0
tableName:show_table2
owner:admintest
location:hdfs://hacluster/user/hive/warehouse/show_schema.db/show_table2
partitioned:false
partitionColumns:
totalNumberFiles:0
totalFileSize:0
(1 row)
-- Query the detailed information about tables whose names start with "from" or "show".
show table extended like 'from*|show*';
tab_name
tableName show_table1
owner admintest
location hdfs://hacluster/user/hive/warehouse/show_table1
InputFormat org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
OutputFormat org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
columns struct columns {int a,string b}
partitioned false
partitionColumns
totalNumberFiles 0
totalFileSize null
tableName from_table1
owner admintest
location hdfs://hacluster/user/hive/warehouse/from_table1
partitioned false
partitionColumns
totalNumberFiles 0
totalFileSize null
tableName show_table2
owner admintest
location hdfs://hacluster/user/hive/warehouse/show_table2
partitioned false
partitionColumns
totalNumberFiles 0
totalFileSize null
(1 row)
-- Query the detailed information about the page_views table in the web schema.
show table extended from web like 'page*';
tab_name
tableName:page_views
owner:admintest
columns:struct columns {timestamp view_time,bigint user_id,string page_url}
partitioned:true
partitionColumns: struct partition_columns {date ds,string country}
totalNumberFiles:0
totalFileSize:0
(1 row)
