DROP MATERIALIZED VIEW
Syntax
DROP MATERIALIZED VIEW [IF EXISTS] view_name
This statement is used to delete a materialized view. If the view to be deleted does not exist and the if exists parameter is used, no error occurs.
If a materialized view is deleted, metadata and table data associated with it will also be deleted.
   A materialized view will fail to delete if some data (metadata or table data) has been deleted before the materialized view is deleted.
Example
- Create a table.
hetuengine:tpcds_2gb> create table t1 (id int, c1 varchar); hetuengine:tpcds_2gb> Insert into t1 values (1,'abc'), (2,'abc2'), (3,'abc3'), (4,'abc4'), (5,'abc5'), (6,'abc6');
 - Create a materialized view.
hetuengine:tpcds_2gb> create materialized view mv.tpcds.t1 as select c1 from t1 where id <7;
 - Delete a specified view. If the view does not exist, an error occurs.
hetuengine:tpcds_2gb> drop materialized view mv.tpcds.t1; Query 20211206_095415_00003_k4wwu failed: line 1:1: MATERIALIZED VIEW 'mv.tpcds.t1' does not exist
 - Delete a specified materialized view with the if exists parameter set. If the view exists, it will be deleted. If the view does not exist, no error occurs.
hetuengine:tpcds_2gb> drop materialized view if exists mv.tpcds.t1; DROP MATERIALIZED VIEW
