On this page
CREATE FUNCTION
Updated on 2024-12-13 GMT+08:00
Syntax
CREATE FUNCTION qualified_function_name (
parameter_name parameter_type
RETURNS return_type
[ COMMENT function_description ]
[ LANGUAGE [ JAVA ] ]
[ SPECIFIC specificName ]
[ DETERMINISTIC | NOT DETERMINISTIC ]
[ RETURNS NULL ON NULL INPUT | CALLED ON NULL INPUT ]
[ SYMBOL class_name ]
[ URI hdfs_path_to_jar ]
It is used to create a function based on a given definition.
  • Each function is uniquely identified by a qualified name and parameter type list. The value format of qualified_function_name must be catalog.schema.function_name. You can plan and manage the function namespace (its format is catalog.schema). It is irrelevant to the concepts of catalog and schema in HetuEngine. The value of parameter_type must be a data type supported by HetuEngine.
  • The value of return_type must be a data type supported by HetuEngine and must match the actual type returned by the function. Forcible type conversion is not executed.
  • You can specify a group of features to decorate a function and specify its behavior. Each feature can be specified only once. For details, see Table 1.
    Table 1 Feature description
    Feature
    Default Value
    Language clause
    Language used to define a function. Currently, Java is supported.
    • Java function: A JAR file for implementing a function needs to be provided, and the JAR file needs to be placed in HDFS that can be read by HetuEngine.
    Deterministic characteristic
    NOT DETERMINISTIC
    Whether a function is deterministic.
    • DETERMINISTIC: A function is considered deterministic if it always returns the same result set when called with the same input set.
    • NOT DETERMINISTIC: A function is considered nondeterministic if it does not return the same result set when called with the same input set.
    Null-call clause
    Function behavior.
    • RETURNS NULL ON NULL INPUT: When NULL is used as a function parameter, NULL is returned.
    • CALLED ON NULL INPUT: When NULL is used as a function parameter, the function is called.
    Symbol class_name
    Used by a Java function to specify a fully qualified class name for function implementation.
    Uri hdfs_path_to_jar
    Used by a Java function to specify a JAR file path for function implementation.
Remarks
  • Permissions are controlled only based on user groups. For details, see Table 2.
    Table 2 Permission control
    Operation
    Permission Control
    CREATE
    No permission control
    DROP
    Only the owner has the permission to perform the operation.
    SELECT
    SHOW
Example
  • Create a Java function example.default.add_two. (You need to build and deploy the UDF first.)
    CREATE FUNCTION example.default.add_two (
     num integer
    RETURNS integer
    LANGUAGE JAVA
    DETERMINISTIC
    SYMBOL "com.example.functions.AddTwo"
    URI "hdfs://hacluster/udfs/function-1.0.jar";
    -- Execute the function.
    select hetu.default.add_two(2);
