Updated on 2025-08-15 GMT+08:00
CREATE TABLE
Syntax
CREATE TABLE [ IF NOT EXISTS ]
[catalog_name.][db_name.]table_name (
{ column_name data_type [ NOT NULL ]
[ COMMENT col_comment]
[ WITH ( property_name = expression [, ...] ) ]
| LIKE existing_table_name
[ { INCLUDING | EXCLUDING } PROPERTIES ]
[ COMMENT table_comment ]
2
CREATE [EXTERNAL] TABLE [IF NOT EXISTS]
[ COMMENT comment ]
[COMMENT 'table_comment']
[PARTITIONED BY(col_name data_type, ....)]
[CLUSTERED BY (col_name, col_name, ...) [SORTED BY (col_name, col_name, ...)] INTO num_buckets BUCKETS]
[ROW FORMAT row_format]
[STORED AS file_format]
[LOCATION 'hdfs_path']
[TBLPROPERTIES (orc_table_property = value [, ...] ) ]
3
[ COMMENT comment ]
[SORT BY ([column [, column ...]])]
Remarks
  • bucket_count can be set for the session attribute. The default value is -1, indicating that bucket_count is not set. During partitioned table creation, if bucket_count is set to -1 and buckets is not set in the table creation statement, the default value 16 is used.
  • By default, external tables are stored in /user/hive/warehouse/{schema_name}/{table_name}. schema_name indicates the schema used for creating a table, and table_name indicates the table name.
  • Setting "transactional=true" enables tables to support atomicity, consistency, isolation, and durability (ACID). However, after a table is defined as a transaction table, it cannot be degraded to a non-transaction table by setting "transactional=false".
    When transactional='true' or '0' is executed, type conversion will not be performed. Therefore, the following exception is thrown:
    Cannot convert ['true'] to boolean
    Cannot convert ['0'] to boolean
  • By default, data cannot be inserted into a managed table whose property external is set to true. To use this function, add custom Hive property hive.non-managed-table-writes-enabled=true. For details, see Precautions.
  • The MPPDB has a restriction that a database identifier can contain no more than 63 characters. If the identifier name exceeds the maximum length, the excess part is automatically truncated.
  • Table creation is not supported in cross-domain scenarios.
Creates a new empty table with specified columns by using CREATE TABLE. Use the CREATE TABLE AS statement to create a table with data.
  • When the optional parameter IF NOT EXISTS is used, no error is reported if the table already exists.
  • The WITH clause can be used to set properties for a newly created table or a single column, such as the storage location of the table and whether the table is an external table.
  • The LIKE clause is used to include all column definitions from an existing table in a new table. You can specify multiple LIKE clauses to allow columns to be copied from multiple tables. If INCLUDING PROPERTIES is specified, all table properties are copied to the new table. If the attribute name specified in the WITH clause is the same as the copied attribute name, the value in the WITH clause is used. By default, the EXCLUDING PROPERTIES attribute is used. You can specify the INCLUDING PROPERTIES attribute for only one table.
  • PARTITIONED BY is used to specify the column for partitioning. CLUSTERED BY is used to specify the column for bucketing. SORT BY and SORTED BY are used to sort columns used for bucketing. BUCKETS can be used to specify the number of buckets. EXTERNAL can be used to create foreign tables. STORED AS can be used to specify the file storage format. LOCATION can be used to specify the storage path in HDFS.
To view the supported column properties, run the following statement:
SELECT * FROM system.metadata.column_properties;
To view the supported table properties, run the following statement:
SELECT * FROM system.metadata.table_properties;
The following table lists the query result when the catalog is hive.
SELECT * FROM system.metadata.table_properties where catalog_name = 'hive';
catalog_name
property_name
default_value
type
description
hive
auto_purge
false
boolean
Skip trash when table or partition is deleted
hive
avro_schema_url
varchar
URI pointing to Avro schema for the table
hive
bucket_count
0
integer
Number of buckets
hive
bucketed_by
array(varchar)
Bucketing columns
hive
bucketing_version
integer
Bucketing version
hive
csv_escape
varchar
CSV escape character
hive
csv_quote
varchar
CSV quote character
hive
csv_separator
varchar
CSV separator character
hive
external_location
varchar
File system location URI for external table
hive
format
ORC
varchar
Hive storage format for the table. Possible values: [ORC, PARQUET, AVRO, RCBINARY, RCTEXT, SEQUENCEFILE, JSON, TEXTFILE, TEXTFILE_MULTIDELIM, CSV]
hive
orc_compress
GZIP
varchar
Compression codec used. Possible values: [NONE, SNAPPY, LZ4, ZSTD, GZIP, ZLIB]
hive
orc_compress_size
262144
bigint
orc compression size
hive
orc_row_index_stride
10000
integer
no. of row index strides
hive
orc_stripe_size
67108864
bigint
orc stripe size
hive
orc_bloom_filter_columns
array(varchar)
ORC Bloom filter index columns
hive
orc_bloom_filter_fpp
0.05
double
ORC Bloom filter false positive probability
hive
partitioned_by
array(varchar)
Partition columns
hive
sorted_by
array(varchar)
Bucket sorting columns
hive
textfile_skip_footer_line_count
integer
Number of footer lines
hive
textfile_skip_header_line_count
integer
Number of header lines
hive
transactional
false
boolean
Is transactional property enabled
Example
  • Create a new table orders and use the WITH clause to specify the storage format, storage location, and whether the table is a foreign table.
    The auto.purge parameter can be used to specify whether to clear related data when data removal operations (such as DROP, DELETE, INSERT OVERWRITE, and TRUNCATE TABLE) are performed.
    • If it is set to true, metadata and data files are cleared.
    • If it is set to false, only metadata is cleared and data files are moved to the HDFS trash bin. The default value is false. You are advised not to change the value. Otherwise, deleted data cannot be restored.
    CREATE TABLE orders (
    orderkey bigint,
    orderstatus varchar,
    totalprice double,
    orderdate date
    WITH (format = 'ORC', location='/user',orc_compress='ZLIB',external=true, "auto.purge"=false);
    -- You can run the DESC FORMATTED statement to view details about table creation.
    desc formatted  orders ;
                               Describe Formatted Table
     # col_name      data_type      comment
     orderkey      bigint
     orderstatus      varchar
     totalprice      double
     orderdate      date
     # Detailed Table Information
     Database:                   default
     Owner:                      admintest
     LastAccessTime:             0
     Table Type:                 EXTERNAL_TABLE
     # Table Parameters:
            EXTERNAL                TRUE
            auto.purge              false
            orc.compress.size       262144
            orc.compression.codec   ZLIB
            orc.row.index.stride    10000
            orc.stripe.size         67108864
            presto_query_id         20220812_084110_00050_srknk@default@HetuEngine
            presto_version          1.2.0-h0.cbu.mrs.320.r1-SNAPSHOT
            transient_lastDdlTime   1660293670
     # Storage Information
     SerDe Library:              org.apache.hadoop.hive.ql.io.orc.OrcSerde
     InputFormat:                org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
     OutputFormat:               org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
     Compressed:                 No
     Num Buckets:                -1
     Bucket Columns:             []
     Sort Columns:               []
     Storage Desc Params:
            serialization.format    1
    (1 row)
  • Create a table with the specified row format.
    -- When creating a table, use commas (,) to separate fields in each record in the data file.
    CREATE TABLE student(
    id string,birthday string,
    grade int,
    memo string)
    ROW FORMAT DELIMITED FIELDS TERMINATED BY ',';
    -- When creating a table, specify the field delimiter and newline character as '\t' and '\n', respectively.
    CREATE TABLE test(
    id int,
    name string ,
    tel string)
    ROW FORMAT DELIMITED FIELDS TERMINATED BY '\t'
    LINES TERMINATED BY '\n'
    STORED AS TEXTFILE;
  • If the orders table does not exist, create the orders table and add table comments and column comments:
    CREATE TABLE IF NOT EXISTS orders (
    orderkey bigint,
    totalprice double COMMENT 'Price in cents.',
    orderdate date
    COMMENT 'A table to keep track of orders.';
    insert into orders values
    (202011181113,'online',9527,date '2020-11-11'),
    (202011181114,'online',666,date '2020-11-11'),
    (202011181115,'online',443,date '2020-11-11'),
    (202011181115,'offline',2896,date '2020-11-11');
  • Create the bigger_orders table using the column definition of the orders table:
    CREATE TABLE bigger_orders (
    another_orderkey bigint,
    LIKE orders,
    another_orderdate date
    SHOW CREATE TABLE bigger_orders ;
                                Create Table
     CREATE TABLE hive.default.bigger_orders (
        orderkey bigint,
        totalprice double,
        ordersdate date,
     WITH (
        external = false,
        format = 'ORC',
        location = 'hdfs://hacluster/user/hive/warehouse/bigger_orders',
        orc_compress = 'GZIP',
        orc_compress_size = 262144,
        orc_row_index_stride = 10000,
        orc_stripe_size = 67108864
    (1 row)
  • 1Example of creating a table:
    CREATE EXTERNAL TABLE hetu_test (orderkey bigint, orderstatus varchar, totalprice double, orderdate date) PARTITIONED BY(ds int) SORT BY (orderkey, orderstatus) COMMENT 'test' STORED AS ORC LOCATION '/user' TBLPROPERTIES (orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = 'orderstatus,totalprice');
  • 2Example of creating a table:
    CREATE EXTERNAL TABLE hetu_test1 (orderkey bigint, orderstatus varchar, totalprice double, orderdate date) COMMENT 'test' PARTITIONED BY(ds int) CLUSTERED BY (orderkey, orderstatus) SORTED BY (orderkey, orderstatus) INTO 16 BUCKETS STORED AS ORC LOCATION '/user'  TBLPROPERTIES (orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = 'orderstatus,totalprice');
  • 3Example of creating a table:
    CREATE TABLE hetu_test2 (orderkey bigint, orderstatus varchar, totalprice double, orderdate date, ds int) COMMENT 'This table is in Hetu syntax' WITH (partitioned_by = ARRAY['ds'], bucketed_by = ARRAY['orderkey', 'orderstatus'], sorted_by = ARRAY['orderkey', 'orderstatus'], bucket_count = 16, orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = ARRAY['orderstatus', 'totalprice'], external = true, format = 'orc', location = '/user');
  • Run the following statements to view the table:
    show create table hetu_test1;
                               Create Table
     CREATE TABLE hive.default.hetu_test1 (
        orderkey bigint,
        totalprice double,
        orderdate date,
        ds integer
     COMMENT 'test'
     WITH (
        bucket_count = 16,
        bucketed_by = ARRAY['orderkey','orderstatus'],
        bucketing_version = 1,
        external_location = 'hdfs://hacluster/user',
        format = 'ORC',
        orc_bloom_filter_columns = ARRAY['orderstatus','totalprice'],
        orc_bloom_filter_fpp = 5E-2,
        orc_stripe_size = 67108864,
        sorted_by = ARRAY['orderkey','orderstatus']
    (1 row)
Create a partitioned table.
--Create a schema.
CREATE SCHEMA hive.web WITH (location = 'hdfs://hacluster/user');
--Create a partitioned table.
CREATE TABLE hive.web.page_views (
  view_time timestamp,
  user_id bigint,
  page_url varchar,
  ds date,
  country varchar
WITH (
  format = 'ORC',
  partitioned_by = ARRAY['ds', 'country'],
  bucketed_by = ARRAY['user_id'],
  bucket_count = 50
--Insert an empty partition.
CALL system.create_empty_partition(
    schema_name => 'web',
    table_name => 'page_views',
    partition_columns => ARRAY['ds', 'country'],
    partition_values => ARRAY['2020-07-17', 'US']);
    partition_values => ARRAY['2020-07-18', 'US']);
--View the partition.
SELECT * FROM hive.web."page_views$partitions";
     ds     | country
 2020-07-18 | US
 2020-07-17 | US
--Insert data.
insert into hive.web.page_views values(timestamp '2020-07-17 23:00:15',bigint '15141','www.local.com',date '2020-07-17','US' );
insert into hive.web.page_views values(timestamp '2020-07-18 23:00:15',bigint '18148','www.local.com',date '2020-07-18','US' );
--Query data.
 select * from hive.web.page_views;
        view_time        | user_id |   page_url    |     ds     | country
 2020-07-17 23:00:15.000 |   15141 | www.local.com | 2020-07-17 | US
2020-07-18 23:00:15.000 |   18148 | www.local.com | 2020-07-18 | US
