CREATE SCHEMA
CREATE (DATABASE|SCHEMA) [IF NOT EXISTS] database_name
[COMMENT database_comment]
[LOCATION hdfs_path]
[WITH DBPROPERTIES (property_name=property_value,...)];
[WITH (property_name=property_value,...)]
This statement is used to create an empty schema. A schema is a container for tables, views, and other database objects. If the optional parameter IF NOT EXISTS is specified and a schema with the same name already exists in the system, no error is reported.
The default schema path is hdfs://hacluster/user/hive/warehouse/.
Example
- Creating a schema named "web":
CREATE SCHEMA web;
- Create a schema in the specified path. The following is an example:
CREATE SCHEMA test_schema_5 LOCATION '/user/hive';
 - Run the following command to create a schema named sales in the catalog named Hive:
CREATE SCHEMA hive.sales;
- If the schema named traffic does not exist in the current catalog, run the following command to create a schema named traffic:
CREATE SCHEMA IF NOT EXISTS traffic;
 - Create a schema with attributes:
CREATE DATABASE createtestwithlocation COMMENT 'Holds all values' LOCATION '/user/hive/warehouse/create_new' WITH dbproperties('name'='akku', 'id' ='9'); --Use the describe schema|database statement to query the schema created: describe schema createtestwithlocation;
