Using Spark SQL Statements Without Aggregate Functions for Correlated Subqueries
If you are using open-source Spark SQL, the aggregate function must be used for correlated subqueries. Otherwise, "Error in query: Correlated scalar subqueries must be aggregated" will be reported. MRS allows you to perform correlated subqueries without using aggregate functions.
Notes and Constraints
- This section applies only to MRS 3.3.1-LTS or later.
- SQL statements similar to select id, (select group_name from emp2 b where a.group_id=b.group_id) as banji from emp1 a is supported.
- SQL statements similar to select id, (select distinct group_name from emp2 b where a.group_id=b.group_id) as banji from emp1 a is supported.
Configuring Parameters
Spark SQL scenario:
- Install the Spark client.
For details, see Installing a Client.
- Log in to the Spark client node as the client installation user.
Modify the following parameters in the {Client installation directory}/Spark/spark/conf/spark-defaults.conf file on the Spark client.
Example Value
spark.sql.legacy.correlated.scalar.query.enabled
Whether Spark SQL supports correlated scalar subqueries without aggregate functions.
- true: Spark SQL supports correlated scalar subqueries without aggregate functions.
- false: Spark SQL does not support correlated scalar subqueries without aggregate functions.
true
Spark Beeline scenario:
For details, see Accessing FusionInsight Manager.
- Choose Cluster > Services > Spark, click Configurations and then All Configurations, and choose JDBCServer(Role) > Customization. Add the spark.sql.legacy.correlated.scalar.query.enabled parameter in the custom area and set its value to true.
- Click Save and save the parameter settings as prompted. Click the Instances tab, select all JDBCServer instances, and choose More > Restart Instance to restart the JDBCServer instances as prompted.
If a correlated subquery uses multiple match predicates, an exception occurs.
Instances are unavailable during the restart, affecting upper-layer services in the cluster. To minimize the impact, perform this operation during off-peak hours or after confirming that the operation does not have adverse impact.
