Triggering TTL Events
Function
A TTL event is triggered based on the interval configured using ttl_configuration. However, you can make the TTL go off immediately.
Syntax
call ttl_policy_run(table => "[table]", path => "[path]", dryRun => [dryRun])
  - If dryRun is true, aged partitions are detected based on the TTL policy configured in the Hudi table and only aged partitions are printed.
 - If dryRun is true, aged partitions are detected based on the TTL policy configured in the Hudi table and only aged partitions are logically deleted. The logical deletion operation generates a repalcecommit. When the clean operation is performed, the aged partitions are automatically and physically deleted.
Parameters
        Parameter  |
        Description  |
        Mandatory  |
        table  |
        Table name. Database name.Table name is also supported. The value is a string.  |
        No. Specify either table or path.  |
        path  |
        Absolute path of the table. The value is a string.  |
        dryRun  |
        The value is of the Boolean type.  |
        No. The value can be false or true. The default value is false.  |
Examples
Make a TTL go off and execute the deletion immediately.
call ttl_policy_run(table => "hudi_table", dryRun => false)
