Updated on 2025-07-16 GMT+08:00
MemArtsCC Logs
Log path: /var/log/Bigdata/memartscc
Archive rule: Automatic compression and archive is enabled for MemArtsCC run logs. When the size of a log file exceeds 50 MB (the size is configurable), the log file is automatically compressed. The number of compressed files can be retained is configurable.
Table 1 MemArtsCC logs
Log Type
Log File Name
Run log
check-sidecar-instance.log
Sidecar health check log
check-worker-instance.log
Worker health check log
check-service.log
Health check log of the MemArtsCC service
cleanup-service.log
MemArtsCC service cleanup log
install-service.log
MemArtsCC service installation log
sidecarStartDetail.log
Sidecar startup log
sidecarStopDetail.log
Sidecar stop log
workerStartDetail.log
Worker startup log
workerStopDetail.log
Worker stop log
Worker log
cc-worker-console.Log generation time
Worker startup log
ccworker.Log level.Log generation time
Worker run log
Sidecar log
cc-sidecar-zk.log
ZooKeeper operation log of sidecar
cc-sidecar-bg-task.log
Sidecar backend task log
cc-sidecar-cli.log
Sidecar command execution log
cc-sidecar.log
Sidecar run log
Log levels
Table 2 describes the log levels provided by MemArtsCC.
The log levels are ERROR, WARN, INFO, and DEBUG in descending order of priority. Only logs whose levels are higher than or equal to the specified level are recorded. The higher the log level specified, the fewer the logs are recorded.
Table 2 Log levels
Level
ERROR
Logs of this level record error information about system running
WARN
Logs of this level record exception information about the current event processing
INFO
Logs of this level record normal running status information about the system and events
DEBUG
Logs of this level record the system information and system debugging information
To modify log levels, perform the following operations:
  2. Choose Cluster > Services > MemArtsCC. Click Configurations and then All Configurations.
  3. On the menu bar on the left, select the log menu of the target role.
  4. Select a desired log level.
  5. Click Save. In the displayed dialog box, click OK to save the configuration.
  6. Click Instances, select all CCSideCar instances, and choose More > Restart Instance.
    Upon completing the configuration, a restart of CCSideCar is necessary. There is no need to restart CCWorker.
