Updated on 2025-07-16 GMT+08:00
Setting Typical MemArtsCC Parameters
Configuration Page
Go to the MemArtsCC configuration page by referring to Modifying Cluster Service Configuration Parameters.
Parameters
Table 1 MemArtsCC configuration parameters
Default Value
access_token_enable
Whether to enable Access token authentication
If this function is enabled, token verification is required when the SDK reads the cache through the worker. When the SDK sends a read request to the worker for the first time, the worker performs Kerberos authentication, generates a key, saves the key to the local host and ZooKeeper, uses the key to generate a token, and returns the token to the SDK. When the SDK sends other read requests to the worker, the token is transferred to the worker for verification with the key, the cache can be read only after the verification is successful.
The value is true for a security cluster and false for a normal cluster.
cache_cap_max_availabe_rate
Ratio of the maximum available capacity on each disk for MemArtsCC
The value ranges from 0.01 to 1.0, and the step is 0.01. This parameter determines the maximum disk capacity (percentage) can be used by MemArtsCC. The default value is 30%. For example, if the disk capacity is 3 TB, the maximum cache space that can be used by the MemArtsCC is 900 GB. If the cache exceeds 900 GB, the MemArtsCC dynamically clears the cache.
0.3
cache_reserved_space
Space to be dynamically reserved for each disk
cache_reserved_space determines the reserved disk space. The default value is 512 MB. Set this parameter to a value greater than 10% of the disk capacity. For example, for a 3 TB disk, set cache_reserved_space to 300 GB and cache_cap_max_available_rate to 30%. If the disk space is less than 300 GB, MemArtsCC dynamically clears the cache even if the cache does not reach the maximum limit (900 GB).
512MB
auto_isolate_broken_disk
Whether to automatically isolate faulty disks
true
broken_disk_list
List of faulty disks
