Configuring the Interconnection Between ClickHouse and Open-Source ClickHouse
For clusters in normal mode (Kerberos authentication disabled), you need to configure CLICKHOUSE_OPENSOURCE_COMMUNITY to interconnect with the open-source or other vendors' ClickHouse. For clusters in security mode (Kerberos authentication enabled), the interconnection is not supported.
Notes and Constraints
This section applies only to MRS 3.3.1-LTS.1 or later.
Parameter Configuration
For details, see Accessing FusionInsight Manager.
- Choose Cluster > Services > ClickHouse. Click Configurations and then All Configurations, choose ClickHouseServer(Role) > Security, and search for and modify the following parameters.
Example Value
Whether to support the interconnection with the open-source ClickHouse.
- false: Interconnection with the open-source ClickHouse is not supported.
- true: Interconnection with the open-source ClickHouse is supported.
true
- Click Save. In the displayed dialog box, click OK to save the configuration. Click Instances, select ClickHouseServer instances, and choose More > Instance Rolling Restart.
