Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Hue/
        Hue Troubleshooting/
      What Should I Do If It Takes a Long Time to Access the Native Hue UI and the File Browser Reports "Read timed out"?
        Updated on 2024-12-13 GMT+08:00
Symptom
What should I do if it takes a long time to access the native Hue UI and the file browser reports "Read timed out"?
Answer
Check whether the HttpFS instance is installed in the HDFS service.
- If no, contact O&M support.
 - If yes, restart the HttpFS instance.
   Parent topic: Hue Troubleshooting
