On this page
Doris Log Overview
Updated on 2024-10-25 GMT+08:00
Log Description
Log path: The default storage path of Doris logs is /var/log/Bigdata/doris/role name.
  • FE: /var/log/Bigdata/doris/fe (run logs) and /var/log/Bigdata/audit/doris/fe (audit logs)
  • BE: /var/log/Bigdata/doris/be (run logs)
  • DBroker: /var/log/Bigdata/doris/dbroker (run logs)
Log archive rule: The automatic compression and archive function is enabled for Doris logs. By default, when the size of a log file exceeds the specified size (configurable), the log file is automatically compressed. The naming rule of the compressed log file is as follows: Original log file name >-<yyyy-mm-dd_hh-mm-ss>. [ID].log.zip. A maximum of 20 latest compressed files are retained. The number of compressed files and compression threshold can be configured.
Table 1 Hive log list
Log type
Log File
Run log
/fe/fe.out
Standard/Error output logs (stdout and stderr)
/fe/fe.log
Main log, including all contents except fe.out
/fe/fe.warn.log
Subset of fe.log. Only WARN and ERROR logs are recorded.
/fe/fe-omm-<Date>-<PID>-gc.log.<No.>
GC logs of the FE process
/fe/preStart.log
Work logs before the FE is started
/fe/check_fe_status.log.log
Log file that records whether the FE service is started successfully
/fe/cleanup.log
Cleanup log file for FE uninstallation
/fe/start_fe.log
FE process startup logs
/fe/stop_fe.log
FE process stop log
/fe/postinstallDetail.log
Work logs generated after the FE is installed and before the FE is started
/be/be.INFO
Run log of the BE process
be.WARNING
Subset of be.log. Only WARN and FATAL logs are recorded.
/be/be-omm-<Date>-<PID>-gc.log.<No.>
GC logs of the BE process
/be/postinstallDetail.log
Work logs generated after BE installation and before BE startup
/be/preStart.log
Work logs before BE startup
/be/cleanup.log
Cleanup log file for BE uninstallation
/be/start_be.log
BE process startup logs
/be/stop_be.log
BE process stop log
/be/check_be_status.log
Log file that records whether the BE service is started successfully
/be/be.out
Standard/Error output logs of the BE process (stdout and stderr)
/dbroker/start_broker.log
Logs indicating that the DBroker process is started or stopped properly
/dbroker/stop_broker.log
DBroker process startup and stop exception logs
/dbroker/preStart.log
Work log before the DBroker is started
/dbroker/cleanup.log
Cleanup log file generated during or before DBroker uninstallation
/dbroker/check_db_status.log
Log file that records whether the DBroker service is started successfully
/dbroker/dbroker-omm-<Date>-<PID>-gc.log.<No.>
GC log of the DBroker process
/dbroker/apache_hdfs_broker.log
Run log of the DBroker process
Viewing Audit Logs
fe.audit.log
Audit log, which records all SQL requests received by the FE
Log Levels
Table 2 describes the log levels provided by the Doris.
The priorities of run log levels are FATAL, ERROR, WARN, and INFO in descending order. Logs whose levels are higher than or equal to the set level are printed. The number of printed logs decreases as the set log level increases.
Table 2 Log Levels
Level
FATAL
FATAL usually indicates a program assertion error.
ERROR
Logs of this level record error information about system running
WARN
Logs of this level record exception information about the current event processing
INFO
Logs of this level record normal running status information about the system and events
To change log levels, perform the following operations:
  1. Log in to FusionInsight Manager and choose Cluster > Services > Doris > Configurations > All Configurations. The All Configurations page of the Doris service is displayed.
  2. On the menu bar on the left, select the log menu of the target role.
  3. Select a desired log level and save the configuration.
  4. Click DashBoard, choose More > Restart Service, and enter the password of the current user to restart the Doris service.
Log Formats
The Doris log format is as follows:
Table 3 Log format
Log type
Format
Example Value
FE run log
<yyyy-MM-dd HH:mm:ss,SSS><LogLevel>(Thread name|Thread ID)<Location where the log event occurs>|<message in log>
2023-04-13 11:17:14,371 INFO (tablet stat mgr|34) [TabletStatMgr.runAfterCatalogReady():125] finished to update index row num of all databases. cost: 0 ms
BE run logs
Log level. I indicates INFO, W indicates WARN, and F indicates FATAL|MMdd HH:mm:ss.SSS. Thread ID. Location where a log event occurs. message&gt in log;
I0413 11:26:03.439189 25248 tablet_manager.cpp:895] begin to build all report tablets info
DBroker run log
<MMdd HH:mm:ss.SSS> <Thread ID> <LogLevel><message in log>
2023-04-11 11:43:13 [ main:0 ] - [ INFO ] starting apache hdfs broker....
Viewing Audit Logs
<yyyy-MM-dd HH:mm:ss,SSS[Operation type] >|<Client>|<User Name>|<Db Name>|<State>|<ErrorCode>|<ErrorMessage>|<Time>|<ScanBytes>|<ScanRows>|<ReturnRows>|<StmtId>|<QueryId>|<IsQuery>|<feIp>|
<Stmt>|<CpuTimeMS>|<SqlHash>|<peakMemoryBytes>|<SqlDigest>|<TraceId>|<FuzzyVariables>
2023-04-13 10:49:26,410 [query] |Client=192.168.64.223:44382|User=root|Db=hivedoris|State=ERR|ErrorCode=1105|ErrorMessage=errCode = 2, detailMessage = (192.168.64.78)[INTERNAL_ERROR]failed to init reader for file /user/hive/warehouse/hivedoris.db/test/000000_0, err: [INTERNAL_ERROR]connect to hdfs failed. error: (255), Unknown error 255), reason: NullPointerException: |Time=67|ScanBytes=0|ScanRows=0|ReturnRows=0|StmtId=91|QueryId=e1125283f12c4994-a69e3a323044d681|IsQuery=true|feIp=192.168.64.78|Stmt=select * from test|CpuTimeMS=0|SqlHash=3bbc220823c3e757002fb9490196cf84|peakMemoryBytes=0|SqlDigest=|TraceId=|FuzzyVariables=
