Exporting Doris Data to HDFS
You can export data in specified tables or partitions in text format through the Broker process or S3 protocol, to remote storage, such as HDFS and object storage.
Export is an asynchronous command. The command output is returned immediately after the command is executed. You can run the SHOW EXPORT; command to view details about the export job.
Notes and Constraints
- You are not advised to export a large amount of data at a time. It is recommended that a maximum of dozens of GB data be exported for an export job. Large exports result in more junk files and higher retry costs.
- If a table contains a large amount of data, you are advised to export the data by partition.
- If the FE is restarted or an active/standby switchover occurs when the export task is running, the task will fail and you will need to submit it again.
- If the export job fails, the temporary directory __doris_export_tmp_xxx generated in the remote storage and the generated files will not be deleted. You need to manually delete them.
- If the export job is successfully executed, the __doris_export_tmp_xxx directory generated in the remote storage may be retained or cleared based on the file system semantics of the remote storage.
For example, in object storage (supporting the S3 protocol), after the last file in a directory is moved through the rename operation, the directory is also deleted. If the directory is not cleared, you can manually clear it.
- After the export is complete (successful or failed), if the FE is restarted or an active/standby switchover occurs, some job information displayed in SHOW EXPORT will be lost and cannot be viewed.
- The Export job exports only Base table data and does not export Rollup Index data.
- The Export job scans data and occupies I/O resources, which may affect the query delay of the system.
Syntax
- Exporting Doris Data to HDFS
- Kerberos authentication is enabled for the cluster (in security mode)
EXPORT TABLE db1.tbl1 PARTITION (p1,p2) [WHERE [expr]] TO "hdfs://IP address of the active NameNode instance:RPC port number/tmp/export/" PROPERTIES ( "label" = "mylabel", "column_separator"=",", "columns" = "col1,col2", "exec_mem_limit"="2147483648", "timeout" = "3600" ) WITH BROKER "broker_name" ( "hadoop.security.authentication"="kerberos", "kerberos_principal"=${doris_keytab_principal}", "kerberos_keytab"="/home/omm/doris_keytab/doris.keytab", "dfs.nameservices" = "hacluster", "dfs.ha.namenodes.hacluster" = "37,36", "dfs.namenode.rpc-address.hacluster.37" = "IP address of the active NameNode instance:RPC port number", "dfs.namenode.rpc-address.hacluster.36" = "IP address of the standby NameNode instance:RPC port number", "dfs.client.failover.proxy.provider.hacluster" = "org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider" );
- Kerberos authentication is disabled for the cluster (in normal mode)
EXPORT TABLE db1.tbl1 PARTITION (p1,p2) [WHERE [expr]] TO "hdfs://IP address of the active NameNode instance:RPC port number/tmp/export/" PROPERTIES ( "label" = "mylabel", "column_separator"=",", "columns" = "col1,col2", "exec_mem_limit"="2147483648", "timeout" = "3600" ) WITH BROKER "broker_name" ( "username" = "user", "password" = "passwd", "dfs.nameservices" = "hacluster", "dfs.ha.namenodes.hacluster" = "37,36", "dfs.namenode.rpc-address.hacluster.37" = "IP address of the active NameNode instance:RPC port number", "dfs.namenode.rpc-address.hacluster.36" = "IP address of the standby NameNode instance:RPC port number", "dfs.client.failover.proxy.provider.hacluster" = "org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider" );
To view the IP addresses of the active and standby NameNode instances, log in to Manager and choose Cluster > Services > HDFS > Instances.
You can log in to Manager, choose Cluster > Services > HDFS > Configurations, and search for dfs.namenode.rpc.port to view the RPC port.
Table 1 describes other parameters.
Table 1 Parameters in the command for exporting Doris data to HDFS Parameter
label
Identifier of the export job. You can use this identifier to view the job status.
column_separator
Column separator. The default value is \t. Invisible characters are supported, for example, \x07.
columns
Columns to be exported. Use commas (,) to separate them. If this parameter is not set, all columns in the table are exported by default.
line_delimiter
Line separator. The default value is \n. Invisible characters are supported, for example, \x07.
exec_mem_limit
Memory usage limit of a query plan on a single BE in an export job. The default value is 2 GB. The unit is byte.
timeout
Job timeout interval. The default value is 2 hours. The unit is second.
tablet_num_per_task
Maximum number of shards allocated to each query plan. The default value is 5.
broker_name
Broker name. You can run the show broker; command on the MySQL client to view the broker name.
kerberos_principal
Principal of the keytab file for accessing the Hadoop cluster.
- For versions earlier than MRS 3.5.0, the value is doris/hadoop.hadoop.com@HADOOP.COM.
- For MRS 3.5.0 and later versions, the format is doris/hadoop.${System domain name in lowercase}@${System domain name}. To obtain the system domain name, log in to Manager, choose System > Permission > Domain and Mutual Trust, and view the value of Local Domain. For example, if the system domain name is A39A7DF8_953D_4772_B909_035A594FFA55.COM, the value of this parameter is doris/hadoop.a39a7df8_953d_4772_b909_035a594ffa55.com@A39A7DF8_953D_4772_B909_035A594FFA55.COM.
kerberos_keytab
keytab file used to access the Hadoop cluster. The file is stored in the ${BIGDATA_HOME}/FusionInsight_Doris_*/install/FusionInsight-Doris-*/doris-be/bin/doris.keytab directory on the FE node. You need to copy the keytab file to all Broker nodes, for example, in /home/omm/doris_keytab, and run the following command to set the owner group of the doris.keytab file:
chown omm:wheel /home/omm/doris_keytab -R
dfs.nameservices
Name of the NameService in the cluster. The value can be found in hdfs-site.xml, which is in the ${BIGDATA_HOME}/FusionInsight_HD_*/1_*_NameNode/etc directory where NameNode is deployed.
Prefix of the NameService in the cluster, containing two values. The value can be found in hdfs-site.xml, which is in the ${BIGDATA_HOME}/FusionInsight_HD_*/1_*_NameNode/etc directory where NameNode is deployed.
Java class for the HDFS client to connect the nodes in Active state in the cluster. The value is org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider.
- Viewing the Status of an Export Job
Run the following command to query the status of the export job.
SHOW EXPORT;
For example, the export job status is as follows.JobId: 14008 State: FINISHED Progress: 100% TaskInfo: {"partitions":["*"],"exec mem limit":2147483648,"column separator":",","line delimiter":"\n","tablet num":1,"broker":"hdfs","coord num":1,"db":"default_cluster:db1","tbl":"tbl3"} Path: hdfs://host/path/to/export/ CreateTime: 2019-06-25 17:08:24 StartTime: 2019-06-25 17:08:28 FinishTime: 2019-06-25 17:08:34 Timeout: 3600 ErrorMsg: NULL 1 row in set (0.01 sec)Table 2 describes the parameters in the command output.
Table 2 Parameters for exporting job status Parameter
JobId
Job ID, which is unique.
State
Job status. The options are as follows:
- PENDING: The job is to be scheduled.
- EXPORTING: Data is being exported.
- FINISHED: The job is successfully exported.
- ANCELLED: The export job fails to be executed.
Progress
Job progress, in the unit of query plan. Assume that there are 10 query plans in total and three of them have been completed. The progress is 30%.
TaskInfo
Job information displayed in JSON format, where:
- db: Database name.
- tbl: Table name
- partitions: Partitions to be exported. * indicates all partitions.
- exec mem limit: Memory usage limit for the query plan, in bytes.
- column separator: Column separator for the exported file.
- line delimiter: Line delimiter for the exported file.
- tablet num: Total number of tablets.
- broker: Name of the used broker.
- coord num: Number of query plans.
Path
Export path on the remote storage device.
CreateTime/StartTime/FinishTime:
Creation time, scheduling start time, and end time of a job.
Timeout
Job timeout interval, in seconds. The time starts from CreateTime.
ErrorMsg
If an error occurs in the job, ErrorMsg displays the cause of the error.
- Canceling an Export Task
After submitting a job, you can run the CANCEL_EXPORT command to cancel the export job. The cancellation command is as follows:
CANCEL EXPORT FROM example_db WHERE LABEL like "%example%";
Prerequisite
- A cluster containing the Doris service has been created, and all services in the cluster are running properly.
- The node to be connected to the Doris database can communicate with the MRS cluster.
- A user with the Doris management permission has been created.
On FusionInsight Manager, create a human-machine user, for example, dorisuser, create a role with Doris administrator permission, and bind the role to the user.
Log in to FusionInsight Manager as the new user dorisuser and change the initial password of the user.
After connecting to Doris as user admin, create a role with administrator permissions, and bind the role to the user.
- The MySQL client has been installed. For details, see Using the MySQL Client to Connect to Doris.
Example of Exporting Doris Data to HDFS
When executing an export job, you can add custom parameters in Related Configuration Parameters as required on the Doris configuration page to improve job export efficiency.
- Log in to the node where MySQL is installed and run the following command to connect to the Doris database.
If Kerberos authentication is enabled for the cluster (in security mode), run the following command.
export LIBMYSQL_ENABLE_CLEARTEXT_PLUGIN=1
Connect to the Doris database.
mysql -uDatabase login user -pDatabase login password -PDatabase connection port -hIP address of the Doris FE instance
- The database connection port is the query connection port of the Doris FE. To obtain the query connection port, you can log in to Manager, choose Cluster > Services > Doris > Configurations, and query the value of query_port of the Doris service.
- To obtain the IP address of the Doris FE instance, log in to Manager of the MRS cluster and choose Cluster > Services > Doris > Instances to view the IP address of any FE instance.
- You can also use the MySQL connection software or Doris web UI to connect the database.
- Run the following command to create a database.
create database if not exists example_db; - Run the following statement to create a table.
CREATE TABLE example_db.test_export_tbl ( `c1` int NOT NULL, `c2` int NOT NULL, `c3` string NOT NULL, `c4` date NOT NULL ) ENGINE=OLAP DUPLICATE KEY(`c1`, `c2`) DISTRIBUTED BY HASH(`c1`) BUCKETS 1; - Run the following command to insert data.
insert into example_db.test_export_tbl values(1,1,1,"2020-02-21"),(2,2,2,"2020-03-21"),(3,3,3,"2020-04-21"); - Run the following command to export data from the test_export_tbl table to HDFS.
EXPORT TABLE example_db.test_export_tbl TO "hdfs://IP address of the active NameNode instance:RPC port number/tmp/export/" PROPERTIES ( "label" = "label_exporthdfs_20230218031", "column_separator"=",", "columns" = "c1,c2,c3,c4", "exec_mem_limit"="2147483648", "timeout" = "3600" ) with broker "broker_192_168_67_78" ( "hadoop.security.authentication"="kerberos", "kerberos_principal"="${doris_keytab_principal}", "kerberos_keytab"="/home/omm/doris_keytab/doris.keytab", "dfs.nameservices" = "hacluster", "dfs.ha.namenodes.hacluster" = "37,36", "dfs.namenode.rpc-address.hacluster.37" = "IP address of the active NameNode instance:RPC port number", "dfs.namenode.rpc-address.hacluster.36" = "IP address of the standby NameNode instance:RPC port number", "dfs.client.failover.proxy.provider.hacluster" = "org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider" );
- Run the following command to query the status of the export job.
SHOW EXPORT;
Log in to FusionInsight Manager, choose Cluster > Services > Doris > Configurations > FE(Role) > Customization, and add the parameters in Table 3 to the custom parameter fe.conf.customized.configs.
Parameter |
Description |
export_checker_interval_second |
Scheduling interval of the export job scheduler. The default value is 5 seconds. After setting this parameter, restart the FE. |
export_running_job_num_limit |
Maximum number of running export jobs. If the value is exceeded, the job waits and is in the PENDING state. The default value is 5. You can adjust the value during job running. |
export_task_default_timeout_second |
Default timeout interval of an export job. The default value is 2 hours. You can adjust the value during job running. |
export_tablet_num_per_task |
Maximum number of shards that can be processed by a query plan. The default value is 5. |
label |
User-customized label of an export job. If this parameter is not specified, a label is automatically generated. |
