Deleting an Index
You can use the global secondary index tool to delete an index.
How to Use
Run the following command on the HBase client to delete an index:
hbase org.apache.hadoop.hbase.hindex.global.mapreduce.GlobalTableIndexer -Dtablename.to.index='table' -Dindexnames.to.drop='idx1#idx2'
The parameters are described as follows:
- tablename.to.index: indicates the name of the table where the index to be deleted is located.
- indexnames.to.drop: indicates the name of the index to be deleted. You can specify multiple indexes and separate them with number signs (#).
