ALTER COLUMN
This section applies only to MRS 3.3.0 or later.
Function
This command is used to change the default values of a column.
Syntax
ALTER TABLE tableIdentifier ALTER COLUMN colName SET DEFAULT defaultValue
Parameter Description
Parameter |
Description |
tableIdentifier |
Table name |
colName |
Column name |
defaultValue |
Default value of a column |
Example
alter table h0_1 alter column extl set default 'new_default_value';
System Response
You can view query results on the client.
