SHOW_FS_PATH_DETAIL
  This topic is available for MRS 3.3.0 or later only.
Function
Checks statistics about a specified FS path.
Syntax
call show_fs_path_detail(path=>'[path]', is_sub=>'[is_sub]', sort=>'[sort]');
Parameters
        Parameter  |
        Description  |
        Mandatory  |
        path  |
        Path of the FS to be queried  |
        Yes  |
        is_sub  |
        The default value is false, indicating that statistics about a specified directory is collected. The value true indicates that statistics about subdirectories in a specified directory is collected.  |
        No  |
        sort  |
        The default value is true, indicating that the results are sorted based on storage_size. The value false indicates that the results are sorted based on the number of files.  |
        No  |
Example
call show_fs_path_detail(path=>'/user/hive/warehouse/hudi_mor/dt=2021-08-28', is_sub=>false, sort=>true);
Returned Result
        Parameter  |
        Description  |
        path_num  |
        Number of subdirectories in a specified directory  |
        file_num  |
        Number of files in a specified directory  |
        storage_size  |
        Size of the directory, in bytes  |
        storage_size(unit)  |
        Size of the directory, in KB  |
        storage_path  |
        Complete FS absolute path of the specified directory  |
        space_consumed  |
        Actual space occupied by the returned files/directories in the cluster, that is, the replication factor set for the cluster is considered.  |
        quota  |
        Name quota, which is a mandatory restriction on the number of files and directory names in the current directory tree  |
        space_quota  |
        Space quota, which is a mandatory restriction on the number of bytes used by files in the current directory tree  |
Response
You can view query results on the client.
