COMPACTION
This topic is available for MRS 3.3.0 or later only.
Function
Compacts Hudi tables. For details, see Hudi Compaction.
Syntax
call run_compaction(op => '[op]', table=>'[table]', path=>'[path]', timestamp=>'[timestamp]');
Parameters
Parameter |
Description |
Mandatory |
op |
Set this parameter to schedule to generate a compaction plan or to run to execute a generated compaction plan. |
Yes |
table |
Name of the table to be queried. The value can be in the database.tablename format. |
No |
path |
Path of the table to be queried |
No |
timestamp |
When op is set to run, you can specify timestamp to execute the compaction plan corresponding to the timestamp and the compaction plan that is not executed before the timestamp. |
No |
Example
call run_compaction(table => 'hudi_table1', op => 'schedule'); call run_compaction(table => 'hudi_table1', op => 'run'); call run_compaction(table => 'hudi_table1', op => 'run', timestamp => 'xxx'); call run_compaction(path => '/user/hive/warehouse/hudi_table1', op => 'run', timestamp => 'xxx');
Precautions
Only MOR tables can be compacted.
Response
You can view query results on the client.
