Updated on 2025-08-22 GMT+08:00
Configuring the Support for Transactions on ClickHouse
Atomicity means that a transaction is an inseparable unit of work. A transaction can contain multiple operations, which are either all executed or none executed. However, some exceptions may occur during transaction execution, for example, a user rolls back a transaction, a connection is disconnected, or a power failure occurs. As a result, the transaction execution is interrupted.
ClickHouse supports atomic write and transaction capabilities. The atomicity of a transaction means that after an operation of a transaction fails, the transaction can be rolled back to the state before the transaction is executed.
Start a ClickHouse transaction.
  • Writing data to local tables achieves better performance. So, multi-replica distributed transactions are recommended for adding, deleting, modifying, and querying data on local tables.
  • When data is written to a distributed table, the distributed table transaction insert_distributed_sync and local table transaction Mergetree/ReplicateMergeTree must be combined to support data writing.
Notes and Constraints
This section applies only to MRS 3.3.0-LTS or later.
Parameters
    For details, see Accessing FusionInsight Manager.
  2. Choose Cluster > Services > ClickHouse. Click Configurations then All Configurations, click Reliability, and search for and modify the following parameters.
    Example Value
    allow_transactions
    Whether to support transactions. The value can be 0 or 1.
    • The default value is 0, indicating that transactions are not supported.
    • Set this parameter to 1, save the configuration, and restart the service for the support for transactions to take effect.
    _clickhouse.metrika.cluster.internal_replication
    Whether to write data to only one replica. The value can be true or false.
    • The default value is true, indicating that data is inserted only to one replica.
    • If this parameter is set to false, data is inserted to both replicas.
    true
  1. After the parameter settings are modified, click Save, perform operations as prompted, and wait until the settings are saved successfully.
  2. After the ClickHouse server configurations are updated, if Configure Status is Expired, restart the component for the configurations to take effect.
    Figure 1 Modifying ClickHouse configurations
    On the ClickHouse dashboard page, choose More > Restart Service or Service Rolling Restart, enter the administrator password, and wait until the service restarts.
    Components are unavailable during the restart, affecting upper-layer services in the cluster. To minimize the impact, perform this operation during off-peak hours or after confirming that the operation does not have adverse impact.
How to Use
  • You can run the set implicit_transaction='true'; statement to use session-level implicit transactions. Currently, ClickHouse does not support interruption of alter queries. If the execution of alter queries (for example, lightweight delete) is interrupted, it cannot be rolled back even if implicit transactions are enabled. This is the same as open-source ClickHouse.
  • To insert data into a distributed table, perform the following steps:
    Log in to FusionInsight Manager, choose Cluster > Services > ClickHouse, click Configurations then All Configurations, and change the value of _clickhouse.metrika.cluster.internal_replication to false. This means that data is written to all replicas of a shard when being inserted to a distributed table.
    At the session level, set insert_distributed_sync='true'; indicates that data is inserted to each actual table in synchronous mode when being inserted to a distributed table.
