JobGateway Logs
Log Description
Log path: /var/log/Bigdata/job-gateway/
Log archive rule: The automatic compression and archive function is enabled for JobGateway run logs. When the total size of all log files exceeds 20 MB (configurable), the log files are automatically compressed into a package named in the format of Original log file name-yyyy-mm-dd.No..log.zip. A maximum of 20 latest compressed files are retained. The number of compressed files and compression threshold can be configured.
Log Type |
Log File Name |
Description |
JobServer run log |
job-gateway.log |
Service run log |
prestart.log |
Service prestart log |
availability-check.log |
Service availability check log |
verbose-gc-sp.txt |
Service GC log |
gc.log |
Service GC log |
JobServer audit log |
access_log.{yyyy-MM-dd}.log |
Service audit log |
Balance run log |
error.log |
Service error log |
prestart.log |
start.log |
Service startup log |
Balance audit log |
access_http.log |
Service audit log |
Log Levels
The following table describes the log levels provided by JobGateway.
The log levels are ERROR, WARN, INFO, and DEBUG in descending order of priority. Only logs whose levels are higher than or equal to the specified level are recorded. The higher the log level specified, the fewer the logs are recorded.
Level |
Description |
ERROR |
Logs of this level record error information about system running |
WARN |
Logs of this level record exception information about the current event processing |
INFO |
Logs of this level record normal running status information about the system and events |
DEBUG |
Logs of this level record the system information and system debugging information |
To modify log levels, perform the following operations:
- Choose Cluster > Services > JobGateway and click Configurations.
- Click All Configurations.
- On the menu bar on the left, select the log menu of the target role.
- Select a desired log level.
- Click Save then OK.
Log Format
The following table lists the JobGateway log formats.
Log Type |
Format |
Example |
Run log |
<yyyy-MM-dd HH:mm:ss> <Log level> <Name of the thread that generates the log > <Name of the class that generates the log:Number of code lines >Message in the log > |
[2024-05-22 10:37:10.000] [INFO ] [job-status-refresh-task-fc1ff7bb-a49f-40bb-ada8-d6793c2bed20] [com.huawei.bigdata.jobgateway.job.task.JobStatusRefreshTask:60] - [start update job task] |
Audit log |
<Remote host name > <Remote username > <Authenticated remote user > <yyyy-MM-dd HH:mm:ss,SSS > < "First line of the log request" Response code Number of sent bytes> |
192.18.212.17 - - [29/Apr/2024:11:51:31 +0800] "GET /mrs/job/wait_nums HTTP/1.1" 200 11 |
