CLEANARCHIVE
  This section applies only to MRS 3.2.1-LTS to MRS 3.3.1-LTS.
Function
Deletes the archive files of Hudi tables to reduce data storage and read/write pressure of Hudi tables.
Syntax
set hoodie.archive.file.cleaner.policy = KEEP_ARCHIVED_FILES_BY_SIZE;
set hoodie.archive.file.cleaner.size.retained = 5368709120;
run cleanarchive on tableIdentifier/tablelocation;
set hoodie.archive.file.cleaner.policy = KEEP_ARCHIVED_FILES_BY_DAYS;
set hoodie.archive.file.cleaner.days.retained = 30;
Parameter Description
        Parameter  |
        Description  |
        tableIdentifier  |
        Name of the Hudi table  |
        tablelocation  |
        Storage path of the Hudi table  |
        hoodie.archive.file.cleaner.policy  |
        Policy for clearing archived files: Currently, only the KEEP_ARCHIVED_FILES_BY_SIZE and KEEP_ARCHIVED_FILES_BY_DAYS policies are supported. The default policy is KEEP_ARCHIVED_FILES_BY_DAYS.
        hoodie.archive.file.cleaner.size.retained  |
        When the deletion policy is KEEP_ARCHIVED_FILES_BY_SIZE, this parameter specifies the number of bytes of archived files to be retained. The default value is 5368709120 bytes (5 GB).  |
        hoodie.archive.file.cleaner.days.retained  |
        When the deletion policy is KEEP_ARCHIVED_FILES_BY_DAYS, this parameter specifies the number of days for storing archived files. The default value is 30 days.  |
Precautions
Archived files are not backed up and cannot be restored after being deleted.
System Response
You can view command execution results in the driver log or on the client.
