Optimizing ClickHouse Table Partitioning
Troubleshooting
  1. Log in to the ClickHouse client and check whether abnormal merge exists.
    select database, table, elapsed, progress, merge_type from system.merges;
  2. Do not perform the INSERT operation too frequently, do not insert a small amount of data, and increase the interval for inserting data.
  3. The data table partitions are not properly allocated. As a result, too many partitions are generated and data tables need to be re-partitioned.
  4. If the MERGE operations are not triggered or slow, adjust the following parameters to accelerate them.
    For details, see Accelerating ClickHouse Merge.
    Configuration Item
    Reference Value
    max_threads
    Number of CPU cores x 2
    background_pool_size
    Number of CPU cores
    merge_max_block_size
    The value is an integer multiple of 8192 and is adjusted based on the CPU and memory resources.
    cleanup_delay_period
    Set this parameter to a value that is appropriately less than the default value 30.
Changing the Value of parts_to_throw_insert
CAUTION:
Increase the value of this parameter only in special scenarios. This configuration acts as a warning for potential issues to some extent. If the cluster hardware resources are insufficient and this configuration is not adjusted properly, potential service issues cannot be detected in a timely manner, which may cause other faults and increase the difficulty of fault recovery.
  • For versions earlier MRS 3.2.0, log in to FusionInsight Manager and choose Cluster > Services > ClickHouse. Click Configurations then All Configurations. Click ClickHouseServer > Customization, find the clickhouse-config-customize parameter, add the configuration in Table 1, save it, and restart the service.
  • For MRS 3.2.0 and later versions, log in to FusionInsight Manager, choose Cluster > ClickHouse > Configurations > All Configurations, search for and change the value of merge_tree.parts_to_throw_insert, save the configurations, and restart the service.
Table 1 Parameters
Name
Value
Memory of ClickHouse instances/32 GB x 300 (conservative estimation)
Verify the modification.
Log in to the ClickHouse client and run the select * from system.merge_tree_settings where name = 'parts_to_throw_insert'; command.
