How Do I Migrate Data from Hive or HDFS to ClickHouse?
Question
How do I migrate Hive/HDFS data to ClickHouse?
Answer
You can export data from Hive as CSV files and import the CSV files to ClickHouse.
- Export data from Hive as CSV files.
hive -e "select * from db_hive.student limit 1000"| tr "\t" "," > /data/bigdata/hive/student.csv;
- Import the CSV files to the student_hive table in the default database of ClickHouse.
clickhouse --client --port 9002 --password xxx -m --query='INSERT INTO default.student_hive FORMAT CSV' < /data/bigdata/hive/student.csv
Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
