Updated on 2025-08-22 GMT+08:00
Quickly Closing HDFS Files
By default, an HDFS file can be closed only if all blocks are reported (in the COMPLETED state). Therefore, the write performance of HDFS is affected by waiting for DataNode blocks and NameNode processing blocks to be reported. For a cluster with heavy load, the waiting consumption has a great impact on the cluster. You can configure the dfs.namenode.file.close.num-committed-allowed parameter of HDFS to close files in advance to improve data write performance. However, data may fail to be read because the block cannot be found or the data block information recorded in the NameNode metadata is inconsistent with that stored in the DataNode. Therefore, this feature does not apply to the scenario where data is read immediately after being written. Exercise caution when using this feature.
This function applies to MRS 3.2.0-LTS.1 or later.
  2. Choose Cluster > Services > HDFS and click the Configurations tab and then All Configurations.
  3. Search for and modify the dfs.namenode.file.close.num-committed-allowed parameter. For more information, see the following table.
    Maximum number of blocks in the COMMITTED state in the file to be closed.
    The default value is 0, indicating that this feature is disabled. If this feature is enabled, the recommended value is 1 or 2.
    For example, if this parameter is set to 1, the file can be closed without waiting for the last block to change to the COMPLETED state.
  4. Save the configuration.
  5. On the Instance page of HDFS, select the active and standby NameNode instances, choose More > Instance Rolling Restart, and wait until the rolling restart is complete.
