DELETE
Function
This command is used to delete records from a Hudi table.
Syntax
DELETE from tableIdentifier [ WHERE boolExpression]
Parameter Description
        Parameter  |
        Description  |
        tableIdentifier  |
        Name of the Hudi table to delete records.  |
        boolExpression  |
        Filtering conditions for deleting records.  |
Examples
- Example 1:
delete from h0 where column1 = 'country';
 - Example 2:
delete from h0 where column1 IN ('country1', 'country2'); - Example 3:
delete from h0 where column1 IN (select column11 from sourceTable2);
 - Example 4:
delete from h0 where column1 IN (select column11 from sourceTable2 where column1 = 'xxx');
 - Example 5:
delete from h0;
System Response
You can view the result in driver logs or on the client.
