CREATE TABLE
Function
This command is used to create a Hudi table by specifying the list of fields along with the table options.
Syntax
CREATE TABLE [ IF NOT EXISTS] [database_name.]table_name
[ (columnTypeList)]
USING hudi
[ COMMENT table_comment ]
[ LOCATION location_path ]
[ OPTIONS (options_list) ]
Parameter Description
        Parameter  |
        Description  |
        database_name  |
        Database name that contains letters, digits, and underscores (_).  |
        table_name  |
        Database table name that contains letters, digits, and underscores (_).  |
        columnTypeList  |
        List of comma-separated columns with data types. The column name contains letters, digits, and underscores (_).  |
        using  |
        Uses hudi to define and create a Hudi table.  |
        table_comment  |
        Description of the table.  |
        location_path  |
        HDFS path. If this parameter is set, the Hudi table will be created as an external table.  |
        options_list  |
        List of Hudi table options.  |
       Parameter  |
       Description  |
       primaryKey  |
       Mandatory. Primary key name. Separate multiple primary key names with commas (,).  |
       type  |
       Type of the table. "cow" indicates a copy-on-write (COW) table, and "mor" indicates a merge-on-read (MOR) table. If this parameter is not specified, the default value is "cow".  |
       preCombineField  |
       The Pre-Combine field in the table. This field is mandatory.  |
       payloadClass  |
       Logic that uses preCombineField for data filtering. DefaultHoodieRecordPayload is used by default. In addition, multiple preset payloads are provided, such as OverwriteNonDefaultsWithLatestAvroPayload, OverwriteWithLatestAvroPayload, and EmptyHoodieRecordPayload.  |
       useCache  |
       Whether to cache table relationships in Spark. This parameter does not need to be configured. This parameter is set to false by default to support the incremental view query of the COW table in Spark SQL.  |
Examples
- Create a non-partitioned table.
create table if not exists hudi_table0 ( id int, name string, price double ) using hudi options ( type = 'cow', primaryKey = 'id', preCombineField = 'price' );
- Create a partitioned table.
create table if not exists hudi_table_p0 ( id bigint, name string, ts bigint, dt string, hh string ) using hudi options ( type = 'cow', primaryKey = 'id', preCombineField = 'ts' ) partitioned by (dt, hh);
 - Create a table in a specified path.
create table if not exists h3( id bigint, name string, price double ) using hudi options ( primaryKey = 'id', preCombineField = 'price' ) location '/path/to/hudi/h3';
- Create a table and specify table attributes.
create table if not exists h3( id bigint, name string, price double ) using hudi options ( primaryKey = 'id', type = 'mor', hoodie.cleaner.fileversions.retained = '20', hoodie.keep.max.commits = '20' );
Precautions
- Currently, Hudi does not support the CHAR, VARCHAR, TINYINT, and SMALLINT data types. You are advised to use the string or INT data type.
 - Currently, only the following types of data support the configuration of default values: int, bigint, float, double, decimal, string, date, timestamp, boolean, and binary.
 - You must specify primaryKey and preCombineField for Hudi tables.
 - When you create a table in a specified path and there already are Hudi tables in the path, you do not need to specify columns during table creation.
System Response
The table is successfully created, and the success message is logged in the system.
