On this page
Creating a CDL Data Synchronization Job
The CDLService web UI provides a visualized page for users to quickly create CDL jobs and import real-time data into the data lake.
A user with the CDL management permission has been created for the cluster with Kerberos authentication enabled.
  1. Access the CDLService web UI as a user with the CDL management permissions or the admin user (for the cluster where Kerberos authentication is not enabled). For details, see Logging In to the CDLService WebUI.
  2. Choose Job Management > Data synchronization task and click Add Job. In the displayed dialog box, set related job parameters and click Next.
    Example Value
    Name
    Job name
    job_pgsqltokafka
    Desc
    Job description
    xxx
  3. On the Job Management page, select and drag the target element from Source and Sink to the GUI on the right.
    MRS 3.2.0:
    MRS 3.3.0 and later versions:
    Double-click the two elements to connect them and set related parameters as required.
    To delete an element, select the element to be deleted and click Delete in the lower right corner of the page.
    Table 1 MySQL job parameters
    Example Value
    Link
    Created MySQL link
    mysqllink
    Tasks Max
    Maximum number of tasks that can be created by a connector. For a connector of the database type, this parameter must be set to 1.
    Mode
    Type of the CDC event to be captured by the job. Value options are as follows:
    • insert
    • update
    • delete
    insert, update, and delete
    DB Name
    MySQL database name
    cdl-test
    Schema Auto Create
    Whether to create table schemas after the job is started
    No
    Connect With Hudi
    Whether to connect to Hudi
    Yes
    DBZ Snapshot Locking Mode
    Lock mode used when a task starts to execute a snapshot. Value options are as follows:
    • minimal: A global read lock is held only when the database schema and other metadata are obtained.
    • extend: A global read lock is held during the entire snapshot execution process, blocking all write operations.
    • none: No lock mode. The schema cannot be changed when a CDL task is started.
      Optional. Click to display this parameter.
    none
    WhiteList
    Whitelisted tables to be captured.
    Separate multiple tables using commas (,). Wildcards are supported.
    (Optional) This parameter is displayed when you click .
    testtable
    BlackList
    Whitelisted tables not to be captured.
    Multi Partition
    Whether to enable multi-partition mode for topics.
    If enabled, you need to set Topic Table Mapping and specify the number of topic partitions, and the data of a single table will be scattered in multiple partitions.
    • The data receiving sequence cannot be ensured. Exercise caution when setting this parameter.
    • The default number of partitions is 5. To change the number of partitions, log in to FusionInsight Manager, choose Cluster > Services > CDL, click Configurations, search for topics.max.partitions in the search box, and change the value to the number of partitions to be changed. For example: Change the value to 10, save the configuration, and restart the CDL service.
    • In MRS 3.3.0 and later versions, if the source table is a partitioned table and this parameter is set to No, the number of topic partitioned tables created using CDL is the number of source table partitions plus 1.
    No
    Topic Table Mapping
    Mapping between topics and tables.
    If configured, table data can be sent to the specified topic. If multi-partitioning is enabled, you need to set the number of partitions, which must be greater than 1. In MRS 3.3.0 and later versions, when the time of the source data is earlier than the specified data filtering time, the data is discarded. When the time of the source data is later than the specified data filtering time, the data is sent to the downstream.
    This parameter is displayed when you click . This parameter is mandatory if Connect With Hudi is set to Yes.
    testtable
    testtable_topic
    2023/03/10 11:33:37 (supported in MRS 3.3.0 and later versions)
    Table 2 PgSQL job parameters
    Example Value
    Link
    Created PgSQL link.
    pgsqllink
    Tasks Max
    Mode
    Type of the CDC event to be captured by the job. The options are as follows:
    • insert
    • update
    • delete
    dbName Alias
    Database name.
    test
    Schema
    Schema of the database to be connected to.
    public
    Slot Name
    Name of the PostgreSQL logical replication slot.
    The value can contain lowercase letters and underscores (_), and cannot be the same in any other job.
    test_solt
    Enable FailOver Slot
    Whether to enable the failover slot function. After it is enabled, the information about the logical replication slot specified as the failover slot is synchronized from the active instance to the standby instance. In this manner, logical subscription can continue even upon an active/standby switchover, implementing the failover of the logical replication slot.
    No
    Slot Drop
    Whether to delete the slot when a task is stopped
    No
    Connect With Hudi
    Whether to connect to Hudi.
    Yes
    Use Exist Publication
    Use a created publication
    Yes
    Publication Name
    Name of a created publication
    This parameter is available when Use Exist Publication is set to Yes.
    test
    Start Time (MRS 3.2.0)
    Start time for synchronizing tables
    2022/03/16 11:33:37
    Data Filter Time (MRS 3.3.0 and later versions)
    Start time of data filtering
    2022/03/16 11:33:37
    WhiteList
    testtable
    BlackList
    Start Position
    Start LSN of the data captured by a task
    Start Txid
    Start TXID of the data captured by a task
    Multi Partition
    No
    Topic Table Mapping
    testtable
    testtable_topic
    Table 3 Source Hudi job parameters (MRS 3.2.0)
    Example Value
    Link
    Link used by the Hudi app
    hudilink
    Interval
    Interval for synchronizing the Hudi table, in seconds
    10
    Start Time
    2022/03/16 11:40:52
    Max Commit Number
    Maximum number of commits that can be pulled from an incremental view at a time.
    10
    Hudi Custom Config
    Customized configuration related to Hudi.
    Table Info
    Detailed configuration information about the synchronization table. Hudi and DWS must have the same table names and field types.
    {"table1":[{"source.database":"base1","source.tablename":"table1"}],"table2":[{"source.database":"base2","source.tablename":"table2"}],"table3":[{"source.database":"base3","source.tablename":"table3"}]}
    Execution Env
    Environment variable required for running the Hudi App. If no ENV is available, manually create one.
    defaultEnv
    Table 4 Source Hudi job parameters (MRS 3.3.0 and later versions)
    Example Value
    Link
    hudilink
    Interval
    10
    Data Filter Time
    Data filtering time
    2023/08/16 11:40:52
    Max Commit Number
    10
    Configuring Hudi Table Attributes
    View for configuring attributes of the Hudi table. The value can be:
    • Visual View
    • JSON View
    Visual View
    Hudi Custom Config
    Table Info
    Table Info-Section Name
    Label name of a single table. Only digits, letters, and underscores (_) are supported.
    Table Info-Source DataBase
    Name of the Hudi database to be synchronized
    base1
    Table Info-Source TableName
    Name of the Hudi table to be synchronized
    table1
    Table Info-Target SchemaName
    Schema name of the target database to which data is written
    Table Info-Target TableName
    Table name of the target database to which data is written
    Table Info-Enable Sink Precombine
    Whether to enable pre-combine for the target database. Currently, the pre-combine function can be enabled only when the target database is DWS.
    This function is used to overwrite existing data at the target when new pre-combine fields are more than the target pre-combine fields. If the new pre-combine fields are less than the target pre-combine fields, new data is discarded
    Yes
    Table Info-Custom Config
    Hudi custom configuration
    Execution Env
    defaultEnv
    Table 5 Source Kafka job parameters (Applicable only to MRS 3.2.0)
    Example Value
    Link
    Created Kafka link
    kafkalink
    Table 6 thirdparty-kafka job parameters
    Example Value
    Link
    Created thirdparty-kafka link
    thirdparty-kafkalink
    DB Name
    Name of the database to be connected to. The name can contain only letters, digits, underscores (_), and hyphens (-), and must start with a letter.
    opengaussdb
    Schema
    Schema of the database to be checked
    oprngaussschema
    Datastore Type
    Type of the upper-layer source. Value options are as follows:
    • MRS 3.2.0:
      • opengauss
      • ogg
      • oracle
      • drs-avro-oracle
    • MRS 3.3.0 and later versions
      • drs-opengauss-json
      • ogg-oracle-avro
      • drs-oracle-json
      • drs-oracle-avro
    • opengauss
    Avro Schema Topic
    Schema topic used by OGG Kafka to store table schemas in JSON format.
    This parameter is available when Datastore Type is set to ogg.
    ogg_topic
    Source Topics
    Source topics can contain letters, digits, and special characters (-,_). Topics must be separated by commas (,).
    topic1
    Tasks Max
    10
    Tolerance
    Fault tolerance policy.
    • none: indicates low tolerance and the Connector task will fail if an error occurs.
    • all: indicates high tolerance and all failed records will be ignored if an error occurs.
    all
    2022/03/16 14:14:50
    2022/03/16 11:33:37
    Kaka Message Format
    Supported formats. The options are as follows:
    • Debezium Json
    • CDL Json
    • Only MRS 3.3.0 and later versions support this parameter.
    • This parameter is available only when Datastore Type is set to drs-opengauss-json.
    CDL Json
    Multi Partition
    Whether to enable multi-partitioning for topics. If it is enabled, you need to set Topic Table Mapping and specify the number of topic partitions, and the data of a single table will be scattered in multiple partitions.
    • In MRS 3.2.0, if Datastore Type is set to ogg or drs-avro-oracle or oracle, the topic multi-partition function cannot be enabled.
    • In MRS 3.3.0 and later versions, when Datastore Type is set to ogg-oracle-avro or drs-oracle-avro or drs-oracle-json, the topic multi-partition function cannot be enabled.
    No
    Topic Table Mapping
    testtable
    testtable_topic
    2023/03/10 11:33:37 (MRS 3.3.0 and later versions)
    Table 7 opengauss job parameters (applicable only to MRS 3.3.0 and later versions)
    Example Value
    Link
    Created openGauss link
    opengausslink
    Tasks Max
    Maximum number of tasks that can be created by the connector. The value is 1.
    Mode
    • insert
    • update
    • delete
    dbName Alias
    Database name.
    test
    Slot Name
    Name of the openGauss logical replication slot
    test_solt
    Slot Drop
    No
    Connect With Hudi
    Yes
    WhiteList
    Whitelisted tables that will be captured.
    testtable
    Data Filter Time
    Data filtering time
    Multi Partition
    • The data receiving sequence cannot be ensured if this function is enabled. Exercise caution when setting this parameter.
    No
    Key Management Tool
    Key management tool. Currently, only his_kms is supported.
    his_kms
    Key Environment Information
    Key information This parameter is available only when Key Management Tool is configured.
    Custom Config
    Custom decoding configuration
    Topic Table Mapping
    Mapping between topics and table. The format of the table name is Schema name.Table name.
    If configured, table data can be sent to the specified topic. If multi-partitioning is enabled, you need to set the number of partitions, which must be greater than 1. When the time of the source data is earlier than the specified data filtering time, the data is discarded. When the time of the source data is later than the specified data filtering time, the data is sent to the downstream.
    cdlschema.testtable
    testtable_topic
    2023/03/10 11:33:37
    Table 8 Sink Hudi job parameters
    Example Value
    Link
    Created Hudi link.
    hudilink
    Path
    Path for storing data.
    /cdldata
    Interval
    Spark RDD execution interval, in seconds.
    Max Rate Per Partition
    Maximum rate for reading data from each Kafka partition using the Kafka direct stream API. It is the number of records per second. 0 indicates that the rate is not limited.
    0
    Parallelism
    Parallelism for writing data to Hudi.
    100
    Target Hive Database
    Database of the target Hive
    default
    • Visual View
    • JSON View
    Visual View
    Global Configuration of Hudi Table Attributes
    Global parameters on Hudi.
    Configuring the Attributes of the Hudi Table
    Configuration of the Hudi table attributes.
    Configuring the Attributes of the Hudi Table: Table Name/Source Table Name (MRS 3.3.0 and later versions)
    Source table name
    Configuring the Attributes of the Hudi Table: Table Type Opt Key
    Hudi table type. The options are as follows:
    • COPY_ON_WRITE
    • MERGE_ON_READ
    MERGE_ON_READ
    Configuring the Attributes of the Hudi Table: Hudi TableName Mapping
    Hudi table name. If this parameter is not set, the name of the Hudi table is the same as that of the source table by default.
    Configuring the Attributes of the Hudi Table: Hive TableName Mapping
    Mapping between Hudi tables and Hive tables.
    Configuring the Attributes of the Hudi Table: Table Primarykey Mapping
    Primary key mapping of the Hudi table
    id
    Configuring the Attributes of the Hudi Table: Table Hudi Partition Type
    Mapping between the Hudi table and partition fields. If the Hudi table uses partitioned tables, you need to configure the mapping between the table name and partition fields. The value can be time or customized.
    time
    Configuring the Attributes of the Hudi Table: Custom Config
    Custom configuration
    In MRS 3.3.0 and later versions, when data is synchronized from MySQL to Hudi, you need to specify the hoodie.datasource.write.precombine.field parameter. If the timestamp and datetime of MySQL support only second-level precision, do not specify fields of timestamp or datetime type, or _hoodie_event_time as the pre-combine field. This function is used to overwrite existing data at Hudi when new pre-combine fields are more than Hudi pre-combine fields. If the new pre-combine fields are less than Hudi pre-combine fields, new data is discarded.
    Execution Env
    Environment variable required for running the Hudi App. If no ENV is available, create one by referring to Configuring CDL ENV Variables.
    defaultEnv
    Table 9 Sink Kafka job parameters
    Example Value
    Link
    Created Kafka link
    kafkalink
    Table 10 DWS job parameters
    Example Value
    Link
    Link used by Connector
    dwslink
    Query Timeout
    Timeout interval for connecting to DWS, in milliseconds
    180000
    Batch Size
    Amount of data batch written to DWS
    50
    Sink Task Number
    Maximum number of concurrent jobs when a table is written to DWS.
    DWS Custom Config
    Table 11 ClickHouse job parameters
    Example Value
    Link
    clickhouselink
    Query Timeout
    Timeout interval for connecting to ClickHouse, in milliseconds
    60000
    Batch Size
    Amount of data batch written to ClickHouse
    It is best practice to set this parameter to a large value. The recommended value range is 10000-100000.
    100000
  4. After the job parameters are configured, drag the two icons to associate the job parameters and click Save. The job configuration is complete.
  5. In the job list on the Job Management page, locate the created jobs, click Start in the Operation column, and wait until the jobs are started.
    Check whether the data transmission takes effect, for example, insert data into the table in the MySQL database and view the content of the file imported to Hudi.
