Integrating CDL Data
CDL is a simple and efficient real-time data integration service. It captures data change events from various OLTP databases and pushes them to Kafka. The Sink Connector consumes data in topics and imports the data to the software applications of big data ecosystems. In this way, data is imported to the data lake in real time.
The CDL service contains two roles: CDLConnector and CDLService. CDLConnector is the instance for executing a data capture job, and CDLService is the instance for managing and creating a job.
You can create data synchronization and comparison tasks on the CDLService WebUI. Figure 1 shows the process of using the CDL.
Data synchronization task
- The CDL supports the following types of data synchronization tasks:
Table 1 Data synchronization task types supported by the CDL Data source
Destination end
MySQL
Hudi
This task synchronizes data from the MySQL database to Hudi.
Kafka
This task synchronizes data from the MySQL database to Kafka.
PgSQL
Hudi
This task synchronizes data from the PgSQL database to Hudi.
Kafka
This task synchronizes data from the PgSQL database to Kafka.
Hudi
DWS
This task synchronizes data from the Hudi database to DWS.
ClickHouse
This task synchronizes data from the Hudi database to ClickHouse.
ThirdKafka
Hudi
This task synchronizes data from the ThirdKafka database to Hudi.
Kafka
This task synchronizes data from the ThirdKafka database to Kafka.
openGuass (supported by MRS 3.3.0 and later versions)
ThirdKafka (DMS/DRS) -> Hudi
Synchronizes data from GaussDB(for openGauss) to Hudi through ThirdKafka (DMS/DRS).
Hudi
Synchronizes data from openGauss to Hudi.
Kafka
Synchronizes data from openGauss to Kafka.
ogg-oracle-avro (supported by MRS 3.3.0 and later versions)
Synchronizes data from avro-oracle to Hudi through ThirdKafka (DMS/DRS).
 - Database versions supported by CDL in a data synchronization task:
    Kafka (including ThirdKafka that uses MRS Kafka as the source), Hudi, and ClickHouse use related components in the MRS cluster as data sources. For details about the version numbers, see List of MRS Component Versions. Table 2 lists the database versions.
 - Usage Constraints:
- If CDL is required, the value of log.cleanup.policy of Kafka must be delete.
 - The CDL service has been installed in the MRS cluster.
 - CDL can capture incremental data only from non-system tables, but not from built-in databases of databases such as MySQL, and PostgreSQL.
 - When data is synchronized from Hudi to DWS or ClickHouse, the data that is deleted from Hudi will not be deleted from the destination. For example, if you run the delete from tableName command in Hudi to physically delete table data, the table data still exists on the destination DWS or ClickHouse.
 - Binary logging (enabled by default) and GTID have been enabled for the MySQL database. CDL cannot fetch tables whose names contain special characters such as the dollar sign ($) or Chinese characters.
To check whether binary logging is enabled for the MySQL database:
Use a tool (Navicat is used in this example) or CLI to connect to the MySQL database and run the show variables like 'log_%' command to view the configuration.
For example, in Navicat, choose File > New Query to create a query, enter the following SQL statement, and click Run. If log_bin is displayed as ON in the result, the function is enabled successfully.
If the bin log function of the MySQL database is not enabled, perform the following operations:
Modify the MySQL configuration file my.cnf (my.ini for Windows) as follows:
server-id = 223344 log_bin = mysql-bin binlog_format = ROW binlog_row_image = FULL expire_logs_days = 10
After the modification, restart MySQL for the configurations to take effect.
To check whether GTID is enabled for the MySQL database:
Run the show global variables like '%gtid%' command to check whether GTID is enabled. For details, see the official documentation of the corresponding MySQL version. (For details about how to enable the function in MySQL 8.x, see https://dev.mysql.com/doc/refman/8.0/en/replication-mode-change-online-enable-gtids.html.)
Set user permissions:
To execute MySQL tasks, users must have the SELECT, RELOAD, SHOW DATABASES, REPLICATION SLAVE and REPLICATION CLIENT permissions.
Run the following command to grant the permissions, Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
GRANT SELECT, RELOAD, SHOW DATABASES, REPLICATION SLAVE, REPLICATION CLIENT ON *.* TO 'Username' IDENTIFIED BY 'Password';
Run the following command to update the permissions:
FLUSH PRIVILEGES;
 - The write-ahead log policy is modified for the PostgreSQL database.
       - The user for connecting to the PostgreSQL database must have the replication permission, the CREATE permission on the database, and is the owner of tables.
 - CDL cannot fetch tables whose names contain special characters such as the dollar sign ($) or Chinese characters.
 - For PostgreSQL databases, you must have the permission to set the statement_timeout and lock_timeout parameters and the permission to query and delete slots and publications.
 - You are advised to set max_wal_senders to 1.5 or 2 times the value of Slot.
 - If the replication identifier of a PostgreSQL table is default, enable the full field completion function in the following scenarios:
- Scenario 1:
When the delete operation is performed on the source database, a delete event contains only the primary key information. In this case, for the delete data written to Hudi, only the primary key has values, and the values of other service fields are null.
 - Scenario 2:
When the size of a single piece of data in the database exceeds 8 KB (including 8 KB), an update event contains only changed fields. In this case, the values of some fields in the Hudi data are __debezium_unavailable_value.
The related commands are as follows:
- Command for querying the replication identifier of a PostgreSQL table:
SELECT CASE relreplident WHEN 'd' THEN 'default' WHEN 'n' THEN 'nothing' WHEN 'f' THEN 'full' WHEN 'i' THEN 'index' END AS replica_identity FROM pg_class WHERE oid = 'tablename'::regclass;
 - Command for enabling the full field completion function for a table:
 - Scenario 1:
- Modify wal_level = logical in the database configuration file postgresql.conf (which is stored in the data folder in the PostgreSQL installation directory by default).
#------------------------------------------------ #WRITE-AHEAD LOG #------------------------------------------------ # - Settings - wal_level = logical # minimal, replica, or logical # (change requires restart) #fsync = on #flush data to disk for crash safety ... - Restart the database service.
# Stop pg_ctl stop # Start pg_ctl start
 - Prerequisites for the DWS database
Before a synchronization task is started, both the source and target tables exist and have the same table structure. The value of ads_last_update_date in the DWS table is the current system time.
 - Prerequisites for ThirdPartyKafka
The upper-layer source supports openGauss and OGG. Kafka topics at the source end can be consumed by Kafka in the MRS cluster.
       ThirdKafka does not support data synchronization from the distributed openGauss database to CDL.
 - Prerequisites for ClickHouse
You have the permissions to operate ClickHouse. For details, see Creating a User with ClickHouse Permissions.
 - Write-ahead logging required for the openGauss database (supported in MRS 3.3.0 and later versions)
       - The user connecting to openGauss databases must have logical replication permission.
 - openGauss interval partitioned tables and Chinese table names cannot be synchronized.
 - If a table in the source openGauss database does not have a primary key, data in the table cannot be deleted.
 - If the data in the source openGauss database needs to be deleted, run the following commands to enable the field completion function:
- Command for querying the replication identifier of a openGauss table:
- Modify wal_level = logical in the database configuration file postgresql.conf (which is stored in the data folder in the openGauss installation directory by default).
Data Types and Mapping Supported by CDL Synchronization Tasks
This section describes the data types supported by CDL synchronization tasks and the mapping between data types of the source database and Spark data types.
        PostgreSQL Data Type  |
        Spark (Hudi) Data Type  |
        int2  |
        int  |
        int4  |
        int  |
        int8  |
        bigint  |
        numeric(p, s)  |
        decimal[p,s]  |
        bool  |
        boolean  |
        char  |
        string  |
        varchar  |
        string  |
        text  |
        string  |
        timestamptz  |
        timestamp  |
        timestamp  |
        timestamp  |
        date  |
        date  |
        json, jsonb  |
        string  |
        float4  |
        float  |
        float8  |
        double  |
        MySQL Data Type  |
        int  |
        int  |
        integer  |
        int  |
        bigint  |
        bigint  |
        double  |
        double  |
        decimal[p,s]  |
        decimal[p,s]  |
        varchar  |
        string  |
        char  |
        string  |
        text  |
        string  |
        timestamp  |
        timestamp  |
        datetime  |
        timestamp  |
        date  |
        date  |
        json  |
        string  |
        float  |
        double  |
        Oracle Data Type  |
        NUMBER(3), NUMBER(5)  |
        bigint  |
        INTEGER  |
        decimal  |
        NUMBER(20)  |
        decimal  |
        NUMBER  |
        decimal  |
        BINARY_DOUBLE  |
        double  |
        CHAR  |
        string  |
        VARCHAR  |
        string  |
        TIMESTAMP, DATETIME  |
        timestamp  |
        timestamp with time zone  |
        timestamp  |
        DATE  |
        timestamp  |
        openGauss JSON  |
        Spark (Hudi)  |
        int2  |
        int  |
        int4  |
        int  |
        int8  |
        bigint  |
        numeric(p,s)  |
        decimal[p,s]  |
        bool  |
        boolean  |
        varchar  |
        string  |
        timestamp  |
        timestamp  |
        timestampz  |
        timestamp  |
        date  |
        date  |
        jsonb  |
        string  |
        json  |
        string  |
        float4  |
        float  |
        float8  |
        double  |
        text  |
        string  |
        Oracle JSON  |
        Spark (Hudi)  |
        number(p,s)  |
        decimal[p,s]  |
        binary double  |
        double  |
        char  |
        string  |
        varchar2  |
        string  |
        nvarchar2  |
        string  |
        timestamp  |
        timestamp  |
        timestamp  |
        date  |
        timestamp  |
        Oracle Avro  |
        Spark (Hudi)  |
        nuber[p,s]  |
        decimal[p,s]  |
        float(p)  |
        float  |
        binary_double  |
        double  |
        char(p)  |
        string  |
        varchar2(p)  |
        string  |
        timestamp(p)  |
        timestamp  |
        date  |
        timestamp  |
        openGauss  |
        Spark (Hudi)  |
        int1  |
        int  |
        int2  |
        int  |
        int4  |
        int  |
        int8  |
        bigint  |
        numeric(p,s)  |
        decimal[p,s]  |
        bool  |
        boolean  |
        char  |
        string  |
        bpchar  |
        string  |
        nvarchar2  |
        string  |
        text  |
        string  |
        date  |
        date  |
        timestamp  |
        timestamp  |
        timestampz  |
        timestamp  |
        json  |
        string  |
        jsonb  |
        string  |
        float4  |
        float  |
        float8  |
        double  |
        real  |
        float  |
        DWS Data Type  |
        int  |
        int  |
        long  |
        bigint  |
        float  |
        float  |
        double  |
        double  |
        decimal[p,s]  |
        decimal[p,s]  |
        boolean  |
        boolean  |
        string  |
        varchar  |
        date  |
        date  |
        timestamp  |
        timestamp  |
        ClickHouse Data Type  |
        int  |
        Int32  |
        long  |
        Int64 (bigint)  |
        float  |
        Float32 (float)  |
        double  |
        Float64 (double)  |
        decimal[p,s]  |
        Decimal(P,S)  |
        boolean  |
        bool  |
        string  |
        String (LONGTEXT, MEDIUMTEXT, TINYTEXT, TEXT, LONGBLOB, MEDIUMBLOB, TINYBLOB, BLOB, VARCHAR, CHAR)  |
        date  |
        Date  |
        timestamp  |
        DateTime  |
Data comparison task
Data comparison checks the consistency between data in the source database and that in the target Hive. If the data is inconsistent, CDL can attempt to repair the inconsistent data. For details, see Creating a CDL Data Comparison Job.
