Updated on 2025-08-22 GMT+08:00
Creating a Hive Table in ZSTD Compression Format
Compressed files can save storage space and speed up data reading from disks data transmission over networks. Hive supports the SNAPPY, ZLIB, Gzip, Bzip2 and ZSTD compression formats.
Zstandard (ZSTD) is an open-source lossless data compression algorithm. It outperforms other Hadoop compression formats in terms of compression performance and compression ratio. This section describes how to create a Hive table in ZSTD compression format. Hive supports ZSTD-compressed files in ORC, RCFile, TextFile, JsonFile, Parquet, SequenceFile, and CSV formats.
For details about other compression formats supported by Hive tables, see Table 1.
Table 1 Compression formats supported by Hive tables
Compression Format
Supported Hive table storage formats
Applicable Scenario
SNAPPY
SNAPPY is featured by extremely high compression and decompression speeds, but fairly moderate in compression ratio.
TextFile, RCFile, SequenceFile, Parquet, and ORC
Suitable for scenarios requiring fast compression and decompression.
ZLIB
ZLIB is featured as an efficient, reliable, and widely used data compression library. Based on the DEFLATE algorithm, ZLIB supports multiple compression levels and streaming processing.
Suitable for scenarios requiring a high compression ratio.
Gzip
Gzip is a widely used compression algorithm. It is featured with a high compression ratio but a low compression and decompression speed.
Gzip works based on ZLIB and compresses data with the DEFLATE algorithm. However, the Gzip compressed files contain some additional metadata.
Suitable for storage scenarios requiring high compression ratio.
Bzip2
Compared with Gzip, Bzip2 is featured with a higher compression ratio but a slower compression and decompression speed.
TextFile and SequenceFile
Suitable for scenarios requiring higher compression ratio, where a lower compression and decompression speed is acceptable.
LZO
Lempel-Ziv-Oberhumer (LZO) is a fast compression algorithm that supports high compression ratio and fast decompression. It is applicable to the Hadoop ecosystem.
TextFile, RCFile, SequenceFile, and Parquet
Suitable for scenarios where the Hadoop ecosystem is used and the fast decompression is required.
ZSTD
ZSTD is an open-source lossless data compression algorithm. It outperforms other compression formats supported by Hadoop in terms of compression performance and compression ratio.
Suitable for scenarios requiring high compression performance and compression ratio.
ZSTD_JNI
ZSTD_JNI is a native implementation of the ZSTD compression algorithm. Compared with ZSTD, ZSTD_JNI has higher compression read/write efficiency and compression ratio, and allows you to specify the compression level as well as the compression mode for data columns in a specific format. For details, see Using the ZSTD_JNI Compression Algorithm to Compress Hive ORC Tables.
ORC
Suitable for scenarios requiring better performance and compression ratio.
  • The cluster client has been installed. For details about how to install the client, see Installing a Client.
  • A Hive service user has been created and granted the permission to create Hive tables. For example, the user has been added to the hive (primary group) and hadoop user groups. For details about how to create a Hive user, see Creating a Hive User and Binding the User to a Role.
  1. Log in to the node where the client is installed as the client installation user.
  2. Go to the client installation directory.
    cd /opt/hadoopclient
  3. Configure environment variables.
    source bigdata_env
  4. Authenticate the user. If Kerberos authentication is not enabled, skip this step.
    kinit Hive service user
  5. Log in to the Hive client.
    beeline
  6. Create a table compressed in ZSTD format. The SQL operations, such as addition, deletion, query, and aggregation, on tables compressed in ZSTD format are the same as those on other common compressed tables.
    • To create a table in ORC format, specify TBLPROPERTIES("orc.compress"="zstd").
      create table tab_1(id string,name string) stored as orc TBLPROPERTIES("orc.compress"="zstd");
    • To create a table in Parquet format, specify TBLPROPERTIES("parquet.compression"="zstd").
      create table tab_2(id string,name string) stored as parquet TBLPROPERTIES("parquet.compression"="zstd");
      To default the compression format of Parquet tables to ZSTD, run the following command on the Hive Beeline client:
      set hive.parquet.default.compression.codec=zstd;
      This command is applied to the current session only.
    • To create a table in other formats or in the general format, set compress.codec to org.apache.hadoop.io.compress.ZStandardCode.
      1. Run the following commands to set the parameters in Table 2:
        set Parameter name=Parameter value;
        Example:
        set hive.exec.compress.output=true;
        Table 2 Setting the compression algorithm of Hive tables to ZSTD
        Value
        Whether to compress the output when Hive executes a query.
        • true: The output is compressed when Hive executes a query.
        • false (default value): The output is not compressed when Hive executes a query.
        true
        mapreduce.map.output.compress
        Whether to compress the output in the Map phase.
        • true: The output in the Map phase is compressed.
        • false (default value): The output in the Map phase is not compressed.
        true
        mapreduce.map.output.compress.codec
        The compression algorithm of the intermediate result output in the Map phase. The algorithm is used to minimize the size of data stored on disks and transmitted over networks, thereby improving the overall data processing efficiency.
        org.apache.hadoop.io.compress.ZStandardCodec
        mapreduce.output.fileoutputformat.compress
        Whether to compress the final output of MapReduce jobs.
        • true: The final output of the MapReduce jobs is compressed.
        • false (default value): The final output of MapReduce jobs is not compressed.
        true
        mapreduce.output.fileoutputformat.compress.codec
        The compression algorithm of the final output of MapReduce jobs. The algorithm is used to reduce the overhead of storage space and network transmission.
        hive.exec.compress.intermediate
        Whether to compress the intermediate result when Hive executes a query.
        • true: The intermediate result is compressed when Hive executes a query.
        • false (default value): The intermediate result is not compressed when Hive executes a query.
        true
      2. Create a Hive table.
        create table tab_3(id string,name string) stored as textfile;
  7. View the table information.
    desc formatted tab_1;
    The command output displays the compression format. The Hive table in ORC format in Figure 1 is compressed in zstd format.
    Figure 1 Viewing table information
