On this page
Show all
Reading the Hudi MOR Table View
After the MOR table is synchronized to Hive, the following two tables are synchronized to Hive: Table name_rt and Table name_ro. The table suffixed with rt indicates the real-time view, and the table suffixed with ro indicates the read-optimized view. For example, if the hudi table ${table_name} is synchronized to Hive, two extra tables ${table_name}_rt and ${table_name}_ro are generated in the Hive table after synchronization.
  • Reading the real-time view (using Hive and SparkSQL as an example): Directly read the Hudi table with suffix _rt stored in Hive.
    select count(*) from ${table_name}_rt;
  • Reading the real-time view (using the Spark DataSource API as an example): The operations are the same as those for the COW table. For details, see the operations for the COW table.
  • Reading the incremental view (using Hive as an example):
    set hive.input.format=org.apache.hudi.hadoop.hive.HoodieCombineHiveInputFormat; // This parameter does not need to be specified for SparkSQL.
    set hoodie.${table_name}.consume.mode=INCREMENTAL;
    set hoodie.${table_name}.consume.max.commits=3;
    set hoodie.${table_name}.consume.start.timestamp=20201227153030;
    select count(*) from default.${table_name}_rt where `_hoodie_commit_time`>'20201227153030';
  • Reading the incremental view (using Spark SQL as an example):
    set hoodie.${table_name}.consume.start.timestamp=20201227153030;  // Specify the initial commit to pull incremental views.
    set hoodie.${table_name}.consume.end.timestamp=20210308212318;  // Specify the end commit to pull incremental views. If this parameter is not specified, the latest commit is used.
  • Incremental view (using the Spark DataSource API as an example): The operations are the same as those for the COW table. For details, see the operations for the COW table.
  • Reading the read-optimized view (using Hive and SparkSQL as an example): Directly read the Hudi table with suffix _ro stored in Hive.
    select count(*) from ${table_name}_ro;
  • Reading the read-optimized view (using the Spark DataSource API as an example): This is similar to reading a common DataSource table.
    QUERY_TYPE_OPT_KEY must be set to QUERY_TYPE_READ_OPTIMIZED_OPT_VAL.
    spark.read.format("hudi")
    .option(QUERY_TYPE_OPT_KEY, QUERY_TYPE_READ_OPTIMIZED_OPT_VAL) // Set the query type to the read-optimized view.
    .load("/tmp/default/mor_bugx/") // Specify the path of the Hudi table to read.
    .createTempView("mycall")
    spark.sql("select * from mycall").show(100)
