Hudi Savepoint
Savepoints are used to save and restore custom version data.
Savepoints provided by Hudi can save different commits so that the cleaner program does not delete them. You can use rollback to restore them later.
Use spark-sql to manage savepoints.
Example:
- Creating a savepoint
call create_savepoint('hudi_test1', '20220908155421949'); - Viewing all existing savepoints
call show_savepoints(table =>'hudi_test1');
- Rolling back a savepoint
call rollback_to_savepoint('hudi_test1', '20220908155421949');
The savepoint rollback command is the same as the commit rollback commands. Both must be rolled back from the latest instant one by one.
MRS 3.1.2: MOR tables do not support savepoints.
