Updated on 2025-07-16 GMT+08:00
Creating a FlinkServer Data Connection
You can use data connections to access different data services. Currently, FlinkServer supports HDFS, Redis, and Kafka data connections.
  1. Access the Flink web UI. For details, see Accessing the FlinkServer Web UI.
  2. Choose System Management > Data Connection Management. The Data Connection Management page is displayed.
  3. Click Create Data Connection. On the displayed page, select a data connection type, enter information by referring to Table 1, and click OK. After the data connection is created, you can edit, test, or delete the data connection in the Operation column.
    Table 1 Parameters for creating a data connection
    Example Value
    Data Connection Type
    Type of the data connection, which can be HDFS, Redis, or Kafka.
    If you select the Redis data connection type, prepare a DCS (for Redis) instance in advance. Ensure that Instance Type is Redis Cluster, Password Protected is No, and Region and VPC are the same as those of the cluster where Flink is located.
    Data Connection Name
    Name of the data connection.
    Cluster Connection
    Cluster connection name in configuration management.
    This parameter is mandatory for HDFS data connections.
    Kafka broker
    Connection information about Kafka broker instances. The format is IP address:Port number. Use commas (,) to separate multiple instances.
    This parameter is mandatory for Kafka data connections.
    192.168.0.1:21005,192.168.0.2:21005
    Redis Deployment Method
    Redis deployment mode. Currently, only Cluster is supported.
    This parameter is mandatory for Redis data connections.
    Cluster
    Redis Server List
    Connection information about Redis instances. The format is IP address:Port number. Use commas (,) to separate multiple instances.
    192.168.0.1:6379,192.168.0.2:6379
    Authentication Mode
    • SIMPLE: indicates that the connected service is in non-security mode and does not need to be authenticated. The Kafka data connection created using this method supports only the SIMPLE authentication type.
    • KERBEROS: indicates that the connected service is in security mode and the Kerberos protocol for security authentication is used for authentication.
    • Redis data connections support SIMPLE and KERBEROS authentication.
    • Kafka data connections support SIMPLE authentication.
