Adding a Hudi Data Source
HetuEngine supports the query of COW, MOR, and MOW table data in MRS 3.5.1 or later. Configure a Hudi data source on HSConsole.
HetuEngine cannot read Hudi bootstrap tables.
Prerequisites for Adding a Hudi Data Source
- You have created the proxy user of the Hudi data source. The proxy user is a human-machine user and must belong to the hive group.
- In the /etc/hosts file of all nodes in the cluster where HetuEngine is located, add the mapping between the host names and IP addresses of the cluster where the data source to be connected is located, and add 10.10.10.10 hadoop.System domain name in the /etc/hosts file (for example, 10.10.10.10 hadoop.hadoop.com). Otherwise, HetuEngine cannot connect to the nodes that are not in the cluster based on the host name.
- You have created a HetuEngine administrator by referring to Creating a HetuEngine Permission Role.
Procedure for Adding a Hudi Data Source
- Obtain the hdfs-site.xml and core-site.xml configuration files of the Hudi data source cluster.
- Log in to FusionInsight Manager of the cluster where the Hudi data source is located.
- In the upper right corner of the homepage, click Download Client to download the complete client to the local PC as prompted.
- Decompress the downloaded client file package and obtain the core-site.xml and hdfs-site.xml files from the FusionInsight_Cluster_1_Services_ClientConfig/HDFS/config directory.
- Check whether the core-site.xml file contains the fs.trash.interval configuration item. If no, add the following configuration items:
<property> <name>fs.trash.interval</name> <value>2880</value> </property>
- Change the value of dfs.client.failover.proxy.provider.NameService name in the hdfs-site.xml file to org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider.
For example, if the NameService name is hacluster, the configuration is as follows:
<property> <name>dfs.client.failover.proxy.provider.hacluster</name> <value>org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider</value> </property>
If the Hudi data source to be connected and HetuEngine are in the same Hadoop cluster, obtain the hdfs-site.xml and core-site.xml configuration files from the HDFS client of the cluster. To be specific, log in to the HDFS client by referring to Using the HDFS Client and run the following commands:
hdfs dfs -get /user/hetuserver/fiber/restcatalog/hive/core-site.xml
hdfs dfs -get /user/hetuserver/fiber/restcatalog/hive/hdfs-site.xml
- Obtain the user.keytab and krb5.conf files of the proxy user of the Hudi data source.
- Choose System > Permission > User.
- Locate the row that contains the target data source user, click More in the Operation column, and select Download Authentication Credential.
- Decompress the downloaded package to obtain the user.keytab and krb5.conf files.
The proxy user of the Hudi data source must be associated with at least the hive user group.
- Obtain the metastore URL and server principal.
- Decompress the client package of the cluster where the Hudi data source is located and obtain the hive-site.xml file from the FusionInsight_Cluster_1_Services_ClientConfig/Hive/config directory.
- Open the hive-site.xml file and search for hive.metastore.uris. The value of hive.metastore.uris is the value of the metastore URL. Search for hive.server2.authentication.kerberos.principal. The value of hive.server2.authentication.kerberos.principal is the value of the server principal.
- Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine. The HetuEngine service page is displayed.
- In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
- Choose Data Source and click Add Data Source. Configure parameters on the Add Data Source page.
- In the Basic Configuration area, set Name and select Hudi for Data Source Type.
- In the Hudi Configuration area, configure the parameters according to Table 1.
Table 1 Hudi configuration Parameter
Example Value
Driver
The default value is hudi.
hudi
hdfs-site File
Select the hdfs-site.xml configuration file obtained in 1. The file name is fixed.
core-site File
Select the core-site.xml configuration file obtained in 1. The file name is fixed.
krb5 File
Configure this parameter when the security mode is enabled.
It is the configuration file used for Kerberos authentication. Select the krb5.conf file obtained in 2.
krb5.conf
- In the Metastore Configuration area, configure the parameters according to Table 2.
Table 2 Metastore configuration Parameter
Example Value
Metastore URL
URL of the metastore of the data source. For details about how to obtain the value, see 3.
thrift://10.92.8.42:21088,thrift://10.92.8.43:21088,thrift://10.92.8.44:21088
Security Authentication Mechanism
After the security mode is enabled, the default value is KERBEROS.
KERBEROS
Server Principal
Specify the username with domain name used by meta to access the metastore. For details about how to obtain the value, see 3.
hive/hadoop.hadoop.com@HADOOP.COM
Client Principal
The parameter format is as follows: username for accessing the metastore@domain name in uppercase.COM.
Username for accessing the metastore is the user to which the user.keytab file obtained in 2 belongs.
admintest@HADOOP.COM
Keytab File
Specify the keytab credential file of the username for accessing the metastore. The file name is fixed. Select the user.keytab file obtained in 2.
user.keytab
- Click OK.
- Log in to the node where the cluster client is located and run the following commands to switch to the client installation directory and authenticate the user:
cd /opt/client
source bigdata_env
kinit User performing HetuEngine operations (If the cluster is in normal mode, skip this step.)
- Log in to the catalog of the data source.
hetu-cli --catalog Data source name --schema Database name
For example, run the following command:
hetu-cli --catalog hudi --schema default
- Run the following command. If the database table information can be viewed or no error is reported, the connection is successful.
show tables;
Hudi Data Type Mapping
Currently, the Hudi data source supports the following data types: INT, BIGINT, FLOAT, DOUBLE, DECIMAL, STRING, DATE, TIMESTAMP, BOOLEAN, BINARY, MAP, STRUCT, and ARRAY.
Performance Optimization
- Metadata caching
Hudi connectors support metadata caching to provide metadata requests for various operations faster. For details, see Adjusting HetuEngine Metadata Caching.
- Dynamic filtering
Enabling dynamic filtering helps optimize the calculation of the Join operator of Hudi connectors. For details, see Enabling Dynamic Filtering in HetuEngine.
- Query with partition conditions
Creating a partitioned table and querying data with partitioning filter criteria help filter out some partition data, improving performance.
Constraints on Hudi Data Sources
Hudi data sources support only the QUERY operation.
