Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HetuEngine/ Adding a HetuEngine Data Source/ Using HetuEngine to Access Data Sources Across Sources and Domains
Updated on 2024-12-13 GMT+08:00
Using the HetuEngine Cross-Source Function
Companies often store large amounts of data from different sources in databases and warehouses to manage and collect information. However, having data from different sources with a variety of structures and scattered storage can make it expensive and time-consuming to query across all of them.
HetuEngine provides unified standard SQL statements to implement cross-source collaborative analysis, simplifying cross-source analysis operations.
Figure 1 HetuEngine cross-source analysis
Technologies and Advantages
  • Compute pushdown: When HetuEngine is used for cross-source collaborative analysis, HetuEngine enhances the compute pushdown capability from the dimensions listed as follows to improve access efficiency.
    • Basic pushdown: predicate, projection, subquery, and limit
    • Aggregate pushdown: GROUP BY, ORDER BY, COUNT, SUM, MIN, and MAX
    • Operator pushdown: <, >, LIKE, and OR.
  • Multi-source heterogeneous data: Collaborative analysis supports both structured data sources such as Hive, GaussDB, and ClickHouse, and unstructured data sources such as HBase and Elasticsearch.
  • Global metadata: A mapping table is provided to map unstructured schemas to structured schemas, enabling HetuEngine to access HBase using SQL statements. Global management for data source information is provided.
  • Global permission control: Data source permissions can be opened to Ranger through HetuEngine for centralized management and control.
Usage Guide of Cross-Source Analysis
HetuEngine supports quick joint query of multiple data sources and GUI-based data source configuration and management. You can quickly add the following data sources on the HSConsole page by referring to Overview of HetuEngine Interactive Query:
Process of Using Cross-Source Collaborative Analysis
  1. Log in to the HetuEngine client by referring to Quickly Using HetuEngine to Access Hive Data Source.
  2. Register data sources such as Hive, HBase, and GaussDB A.
    hetuengine> show catalogs;
      Catalog
    dws
    hive
    hive_dg
    hbase
    system
    systemremote
    (6 rows)
  3. Compile SQL statements for cross-source collaborative analysis.
    select * from hive_dg.schema1.table1 t1 join hbase.schema3.table3 t2 join dws.schema02.table4 t3 on t1.name = t2.item and t2.id = t3.cardNo;
HetuEngine Cross-Domain Function
HetuEngine provide unified standard SQL to implement efficient access to multiple data sources distributed in multiple regions (or data centers), shields data differences in the structure, storage, and region, and decouples data and applications.
Figure 2 HetuEngine cross-region functions
Key Technologies and Advantages
  • No single-point failure bottleneck: HSFabric supports horizontal scale-out and multi-channel parallel transmission, maximizing the transmission rate. Cross-domain latency is no longer a bottleneck.
  • Better computing resource utilization: Data compression and serialization tasks are delivered to Worker for parallel computing.
  • Efficient serialization: The data serialization format is optimized to reduce the amount of data to be transmitted at the same data volume level.
  • Streaming transmission: Based on HTTP 2.0 stream, ensure the universality of the HTTP protocol and reduce the repeated invoking of RPC during the transmission of a large amount of data.
  • Resumable transmission: A large amount of data is prevented from being retransmitted after the connection is interrupted abnormally during data transmission.
  • Traffic control: The network bandwidth occupied by data transmission can be limited by region to prevent other services from being affected due to exclusive traffic occupation in cross-region limited bandwidth scenarios.
Using a Cross-Domain Function
Prerequisites:
  • At least one HSFabric instance has been deployed on the data nodes of the local and remote clusters.
  • The nodes where the HSFabric instances of the local and remote clusters have been deployed can communicate with each other.
  1. Open the data source in the local domain. You can create a virtual schema to shield the real schema information and instance information of the physical data source in the local domain from remote access requests. The remote end can use the virtual schema name to access the data source in the local domain.
    CREATE VIRTUAL SCHEMA hive01.vschema01 WITH (
      catalog = 'hive01',
      schema = 'ins1'
  2. Register the data source of the HetuEngine type on the remote HetuEngine and add the local domain HetuEngine by referring to Adding a Cross-Cluster HetuEngine Data Source.
  3. Use cross-domain collaborative analysis.
    // 1. Open the hive1.ins2 data source on the remote HetuEngine.
    CREATE VIRTUAL SCHEMA hive1.vins2 WITH (
      catalog = 'hive1',
      schema = 'ins2'
    // 2. Register three types of data sources, including Hive, GaussDB A, and HetuEngine, on HetuEngine in the local domain.
      Catalog
    dws
    hetuengine_dc
    hive
    hive_dg
    system
    systemremote
    (6 rows)
    // 3. Perform cross-source collaborative analysis on HetuEngine in the local domain.
    select * from hive_dg.schema1.table1 t1 join hetuengine_dc.vins2.table3 t2 join dws.schema02.table4 t3 on t1.name = t2.item and t2.id = t3.cardNo;
