Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Spark/Spark2x/ Spark FAQ/ Spark SQL and DataFrame/ Why Does Spark-beeline Fail to Run and Error Message "Failed to create ThriftService instance" Is Displayed?
Updated on 2023-04-28 GMT+08:00
Question
Why does "Failed to create ThriftService instance" occur when spark beeline fails to run?
Beeline logs are as follows:
Error: Failed to create ThriftService instance (state=,code=0)
Beeline version 1.2.1.spark by Apache Hive
[INFO] Unable to bind key for unsupported operation: backward-delete-word
[INFO] Unable to bind key for unsupported operation: down-history
[INFO] Unable to bind key for unsupported operation: up-history
beeline>
In addition, the "Timed out waiting for client to connect" error log is generated on the JDBCServer. The details are as follows:
2017-07-12 17:35:11,284 | INFO  | [main] | Will try to open client transport with JDBC Uri: jdbc:hive2://192.168.101.97:23040/default;principal=spark/hadoop.<System domain name>@<System domain name>;healthcheck=true;saslQop=auth-conf;auth=KERBEROS;user.principal=spark/hadoop.<System domain name>@<System domain name>;user.keytab=${BIGDATA_HOME}/FusionInsight_HD_xxx/install/FusionInsight-Spark-*/keytab/spark/JDBCServer/spark.keytab | org.apache.hive.jdbc.HiveConnection.openTransport(HiveConnection.java:317)
2017-07-12 17:35:11,326 | INFO  | [HiveServer2-Handler-Pool: Thread-92] | Client protocol version: HIVE_CLI_SERVICE_PROTOCOL_V8 | org.apache.proxy.service.ThriftCLIProxyService.OpenSession(ThriftCLIProxyService.java:554)
2017-07-12 17:35:49,790 | ERROR | [HiveServer2-Handler-Pool: Thread-113] | Timed out waiting for client to connect.
Possible reasons include network issues, errors in remote driver or the cluster has no available resources, etc.
Please check YARN or Spark driver's logs for further information. | org.apache.proxy.service.client.SparkClientImpl.<init>(SparkClientImpl.java:90)
java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Timed out waiting for client connection.
 at io.netty.util.concurrent.AbstractFuture.get(AbstractFuture.java:37)
 at org.apache.proxy.service.client.SparkClientImpl.<init>(SparkClientImpl.java:87)
 at org.apache.proxy.service.client.SparkClientFactory.createClient(SparkClientFactory.java:79)
 at org.apache.proxy.service.SparkClientManager.createSparkClient(SparkClientManager.java:145)
 at org.apache.proxy.service.SparkClientManager.createThriftServerInstance(SparkClientManager.java:160)
 at org.apache.proxy.service.ThriftServiceManager.getOrCreateThriftServer(ThriftServiceManager.java:182)
 at org.apache.proxy.service.ThriftCLIProxyService.OpenSession(ThriftCLIProxyService.java:596)
 at org.apache.hive.service.cli.thrift.TCLIService$Processor$OpenSession.getResult(TCLIService.java:1257)
 at org.apache.hive.service.cli.thrift.TCLIService$Processor$OpenSession.getResult(TCLIService.java:1242)
 at org.apache.thrift.ProcessFunction.process(ProcessFunction.java:39)
 at org.apache.thrift.TBaseProcessor.process(TBaseProcessor.java:39)
 at org.apache.hadoop.hive.thrift.HadoopThriftAuthBridge$Server$TUGIAssumingProcessor.process(HadoopThriftAuthBridge.java:696)
 at org.apache.thrift.server.TThreadPoolServer$WorkerProcess.run(TThreadPoolServer.java:286)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
 at java.lang.Thread.run(Thread.java:748)
Caused by: java.util.concurrent.TimeoutException: Timed out waiting for client connection.
Answer
This problem occurs when the network is unstable. When a timed-out exception occurs in beeline, Spark does not attempt to reconnect to beeline.
Solution
Restart spark-beeline for reconnection.
