Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Spark/Spark2x/ Spark FAQ/ Spark Core/ Why Do the Executors Fail to Register Shuffle Services During the Shuffle of a Large Amount of Data?
Question
When more than 50 terabytes of data is shuffled, some executors fail to register shuffle services due to timeout. The shuffle tasks then fail. Why? The error log is as follows:
2016-10-19 01:33:34,030 | WARN | ContainersLauncher #14 | Exception from container-launch with container ID: container_e1452_1476801295027_2003_01_004512 and exit code: 1 | LinuxContainerExecutor.java:397
ExitCodeException exitCode=1:
at org.apache.hadoop.util.Shell.runCommand(Shell.java:561)
at org.apache.hadoop.util.Shell.run(Shell.java:472)
at org.apache.hadoop.util.Shell$ShellCommandExecutor.execute(Shell.java:738)
at org.apache.hadoop.yarn.server.nodemanager.LinuxContainerExecutor.launchContainer(LinuxContainerExecutor.java:381)
at org.apache.hadoop.yarn.server.nodemanager.containermanager.launcher.ContainerLaunch.call(ContainerLaunch.java:312)
at org.apache.hadoop.yarn.server.nodemanager.containermanager.launcher.ContainerLaunch.call(ContainerLaunch.java:88)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2016-10-19 01:33:34,031 | INFO | ContainersLauncher #14 | Exception from container-launch. | ContainerExecutor.java:300
2016-10-19 01:33:34,031 | INFO | ContainersLauncher #14 | Container id: container_e1452_1476801295027_2003_01_004512 | ContainerExecutor.java:300
2016-10-19 01:33:34,031 | INFO | ContainersLauncher #14 | Exit code: 1 | ContainerExecutor.java:300
2016-10-19 01:33:34,031 | INFO | ContainersLauncher #14 | Stack trace: ExitCodeException exitCode=1: | ContainerExecutor.java:300
Answer
The imported data exceeds 50 TB, which exceeds the shuffle processing capability. The shuffle may fail to respond to the registration request of an executor in a timely manner due to the heavy load.
The timeout interval for an executor to register the shuffle service is 5 seconds. The maximum number of retries is 3. This parameter is not configurable.
You are advised to increase the number of task retry times and the number of allowed executor failure times.
Configure the following parameters in the spark-defaults.conf file on the client: If spark.yarn.max.executor.failures does not exist, manually add it.
Table 1 Parameter Description
Default Value
spark.task.maxFailures
Specifies task retry times.
4
Specifies executor failure attempt times.
Set spark.dynamicAllocation.enabled to false, to disable the dynamic allocation of executors.
numExecutors * 2, with minimum of 3
Set spark.dynamicAllocation.enabled to true, to enable the dynamic allocation of executors.
3
